Author Topic: alternator broadcast codes  (Read 15497 times)
jvanduerm
« on: September 24, 2013, 03:41:22 PM »
Does anyone know what broadcast code would have been stamped on the alternator of a 350/300 L48 car (69 SS) with air conditioning? The alternator part number is 1100843. I have been told CD was used on cars equiped with AC but wonder if there was any diference on the L48 small block? Thanks in advance for your help.
Re: alternator broadcast codes
« Reply #1 on: September 28, 2013, 11:56:26 PM »
The engine doesn't matter. All 843 alts would have the same broadcast code. And it's not CD, but NF.
Pacecarjeff
    • pacecarjeff.com
« Reply #2 on: October 01, 2013, 02:48:46 AM »
1100693   37 amp   CB
1100834   37 amp   CW
1100814   37 amp   CK
1100837   37 amp   CZ
1102454   37 amp   YG
1100900   42 amp    NW
1100901   42 amp    NX
1100950   42 amp    RF
1100543   42 amp    RG
1100544   61 amp    RH
1100859   42 amp    NP
1100833   42 amp    CV
1100881   42 amp    NR
1100696   42 amp    CS
1100750   61 amp    CD
1100796   61 amp    CH
1100825   61 amp    CT
1100843   61 amp    NL
1100882   61 amp    NS
1100884   61 amp    NT
1102440   37 amp    EC
« Reply #3 on: October 01, 2013, 05:38:29 AM »
Jeff,
Don't know why the difference, but I have lots of broadcast sheets and every 69 AC car is a NF.
jdv69z
  • 69 RS Z/28 52E
« Reply #4 on: October 01, 2013, 01:39:14 PM »
Here's a pic of an 843 alternator from my 71 Chevelle.
Jimmy V.
Pacecarjeff
    • pacecarjeff.com
« Reply #5 on: October 01, 2013, 01:46:02 PM »
oops - - Typo--- NF is correct.
1100693   37 amp   CB
1100834   37 amp   CW
1100814   37 amp   CK
1100837   37 amp   CZ
1102454   37 amp   YG
1100900   42 amp    NW
1100901   42 amp    NX
1100950   42 amp    RF
1100543   42 amp    RG
1100544   61 amp    RH
1100859   42 amp    NP
1100833   42 amp    CV
1100881   42 amp    NR
1100696   42 amp    CS
1100750   61 amp    CD
1100796   61 amp    CH
1100825   61 amp    CT
1100843   61 amp    NF
1100882   61 amp    NS
1100884   61 amp    NT
1102440   37 amp    EC
« Last Edit: October 01, 2013, 02:21:52 PM by Pacecarjeff »
« Reply #6 on: October 01, 2013, 07:00:44 PM »
I don't have all my references here in CR, but 693 is NL (not CB).
Pacecarjeff
    • pacecarjeff.com
« Reply #7 on: October 01, 2013, 07:13:04 PM »
This may be a new can of worms - would the code be different for the same alternator part number when used at Norwood for Camaros, then it was when used at St. Louis for Corvettes.  Cause then there may be lots of changes needed?
Typically my lists are based on Corvette research....
which is farther along then most other Chevrolet car models.
big iron
« Reply #8 on: October 01, 2013, 10:51:41 PM »
How about the 61 amp 1100750, is CD correct?
Bob
« Reply #9 on: October 02, 2013, 02:26:35 AM »
If anyone has an '825' CT laying around..  I'd buy it..  :)
« Reply #10 on: October 12, 2013, 04:36:05 AM »
Shouldn't be. The Anderson (Delco) plant would build the part, stamp the part # and broadcast # on it and ship it to whatever plant needed the order.
« Reply #11 on: October 13, 2013, 03:30:38 PM »
Nope. When some aspect of the alternator changed, its part number changed (like just re-clocking one case half relative to the other), and that also changed the broadcast code.
« Reply #12 on: October 14, 2013, 02:59:01 AM »
That was part of my old job - pulling alternator broadcast codes for new part #'s. If it was a revision, the code would stay the same.
We had a book that we recorded the codes in - the code could be any two digits. (But they progressed in a logical way so we could keep sane.) The code would get picked up in the BOM and would be used in the plants for the broadcast sheets.
David K
  • Dr. Longblock
« Reply #13 on: October 01, 2023, 05:10:19 AM »
Reviving this post. I don’t see a broadcast code for my alternator. 1100817. Any idea?
