Author Topic: First time Camaro gen 1 buyer  (Read 23501 times)
Jbyer8
Re: First time Camaro gen 1 buyer
« Reply #15 on: September 18, 2013, 04:15:18 PM »
And to the comment about bringing someone more knowledgable along with me I wish I could. I did have a member of the local car club look at it for me and he said it drove and looked right. He didn't tear it apart or anything but said it was a nice car.
As for what all was done to it I attached the inspection report above. Dumb question, what exactly does it mean if the visible and hidden vins don't match? Is it not a Camaro?
« Reply #16 on: September 18, 2013, 04:54:23 PM »
Cook DW
I read that the vin doesn't tell you anything about build date. Is that not true?
That is correct.  You can not pin point the date with the vin.  But you can get an idea of if it would be possible.  In 68 the vins started at 300,001 & with the one in question being 363426 that would mean that 63,425 cars were built in the first month or so of production.. To me that is not likely..  Do not take that as gospel; it is just my perception on the production..
MyRed67
  • SZZLN 67
« Reply #17 on: September 18, 2013, 09:04:32 PM »
RED FLAG..
That vin does not line up with the build date...  I would ask the seller to get pictures of the hidden vins..
Welcome to the site.  X2 on the RED FLAG.  At very least I would want to see the Hidden Vins. at this point.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
MyRed67
  • SZZLN 67
« Reply #18 on: September 18, 2013, 09:15:29 PM »
Cook DW
Jbyer8,  look at this link;  http://camaros.org/geninfo.shtml#HowMany
GM did keep records of the last Vin. built each month at each plant.  That Vin. is about 2 months out of line.
1967 Camaro  LOS  11A
« Reply #19 on: September 18, 2013, 09:28:36 PM »
That is not true. VIN's were sequential so knowing the VIN, you can easily tell what month is was made.
Tag is Sept, VIN is December.
I'd guess the VIN was swapped. Not good, no matter what the paperwork says.
MyRed67
  • SZZLN 67
« Reply #20 on: September 18, 2013, 09:41:18 PM »
Jbyer8,
  Don't take this wrong, guys here are not "brow beating" the car, it is a nice car.  Point here is, IF they have changed either the VIN. tag or the Cowl Tag, they probably had a reason for doing so that they are not willing to reveal.  IE, they may have done some serious Body work they don't want to disclose.  The guys here are just trying to give you a "heads up",  could even cause some serious legal issues later if/when you decide to sell the car.  I hope it all works out for you.
1967 Camaro  LOS  11A
lakeholme
  • 68-12D L30/M35
« Reply #21 on: September 18, 2013, 10:04:28 PM »
Jbyer8,
X2 on MYRed67's comment and everyone's caution.
They've obviouslly thrown a lot of parts and restoration cash into this car, but it is still only going to be a driver.  So, don't pay a ton of money if you decide to buy it.  And use just as much mechanical caution as you would in buying any used car.  In other words, even in a non-matching, pieced together car, you don't want to drive away with a lemon that you will never get out of it half of what you put into it.
I do agree, however, the car looks nice.  It could draw notice driving down the street or at a local cruise-in.
Although, according to my taste, I don't see why anyone would restore a great looking butternut 68 with a black vinyl top into a vanilla black and white...  ;D ::) ???
Jbyer8
« Reply #22 on: September 18, 2013, 11:37:48 PM »
I really appreciate everyone's advice and comments. I'm learning alot. Being the new by that I am I've just really fallen for this car. But y'all are giving me perspective. Knowing that the car is a Frankenstein and alot of work has gone into it what is the value of something like this? I know value depends on what you're looking for in a car. Should the dealer selling this car know that the vins don't match? Especially if they did all this work to it? Sorry for beating a dead horse. The car itself has everything I'm looking for in it. I
Jbyer8
« Reply #23 on: September 19, 2013, 02:45:59 AM »
Not that clarification is needed but when asking about price I want to assume the below.
I recognize the fact that its not numbers matching. Factoring in all the work that has been done to it( see earlier post) no visible rust or welding issues and that its not a lemon. Long story short the dealer is asking 32k for it. Am I crazy?
« Reply #24 on: September 19, 2013, 02:58:25 AM »
IMO, if the VIN and the trim tab date do not *align*, then it is much more likely that the Trim plate was changed, than the VIN.  it is against the law to change the VIN plate.   If you check the hidden VIN and it does not match the visible VIN plate, then there are *legal issues* with the car.    If the VINs match the hidden VIN, but the trim plate dates/etc doesn't line up, then it is likely that the trim plate has been changed to reflect a 'more desirable' model or set of options... which isn't illegal, but can drastically affect the value of the car.
Jbyer8
« Reply #25 on: September 19, 2013, 03:39:46 AM »
That thing does look like its been beat to death. Any tell tell signs to inspect to see if its been replaced?
« Reply #26 on: September 19, 2013, 04:02:55 AM »
Others have indicated your TT date and the VIN do NOT match up in time... so if the VIN is the original one (ie. .. matches the hidden VINs), then the TT has been changed, but that  TT is basically a 'manufacturer's plate'..   same as that little plate on the back of most refrigerators, computers,e tc..  which identifies the model number, mfg, etc..   your car will run just FINE without a trim plate.. and it has nothing to do with ownership.  It's only critical if you are *showing* the car in original classes, or 'playing the matching numbers' game..  :)
Note:  If it's true what was posted earlier, that your VIN was for a December built car, and your TT was a September date, then it seems beyond possible that they both were on that car from the factory.
What you should do is this:
1)  Check the hidden VINs against the title VIN and the displayed VIN on the car.   if these do not match, DO NOT THINK ABOUT purchasing this car.  you could pay good money for it, and then have another owner claim the car and you LOSE... everything..  car.. $$$$..  money everything.   You should suggest the current owner run the REAL VIN (the hidden VIN) with law enforcement to check if it's stolen (but DO NOT BUY IT).. :)
2)  IF the VIN's all match, assuring you that the title is the correct one for this car, and you are buying it from the titled owner, and if you like everything else about the car, then you might want to buy it...  you WILL be the legal owner per the VIN and title.
The TT has NOTHING to do with legal ownership.
PS.  Kurt indicated that he thought the VIN was probably changed, but that would indicate a STOLEN car.   IMO that's less likely that the TT was changed out.  LOTS of people change our the Trim Tag simply to make the car look more desirable (ie. take one from a September car and put it on your Dec car).  It's NOT a good thing, but it's not illegal, although it's unethical and immoral... and it's done to *fool* people (namely buyers).
« Reply #27 on: September 19, 2013, 12:13:57 PM »
Cook DW
Cook DW
I stand corrected.  Thanks Mike & Kurt.  I didnt realize that data was available.
Jbyer8
« Reply #28 on: September 19, 2013, 07:28:24 PM »
What would be the easiest way to get to the hidden vin and how would I do it?
« Reply #29 on: September 20, 2013, 02:07:25 AM »
at the very least,you might be able to pear down through the cowl vent(near the passenger wiper arm) with a light and make out the numbers. At the most,you may have to have owner remove cowl vent panel so numbers can be accessed. There is a second set of numbers under the heater fan, but serious diassembly would be needed to see this set. Most would be satisfied if the cowl vent number matches. It is a partial vin starting with 8n------(norwood built) or 8L------(los Angeles) for a 1968 model year. The rest of the vin should match dash vin 363426.All this information is here on this site.Proceed with caution!
