Author Topic: Need paintcode for 67 CC ermine white...  (Read 8703 times)
Iluv69s
« on: September 09, 2013, 11:22:58 AM »
I got a PPG Deltron paintcode from another site, but apparently does not exist anymore. Also need black code also for the stripes.
Im not necesarily going to use Deltron, but I want a BC-CC paint....  any help is appreciated.
Thanks CRG
Max
x66 714
Re: Need paintcode for 67 CC ermine white...
« Reply #1 on: September 09, 2013, 01:29:41 PM »
Try Autocolorlibrary.com or they also go by TCPglobal....Joe
Iluv69s
« Reply #2 on: September 18, 2013, 11:02:01 AM »
thanks joe...but, seems that sight doesnt go back that far...   anyone have a  PPG or Dupont mix code??
 Someone out there must have painted a 67 Pacer lately??    thanks   max
x66 714
« Reply #3 on: September 18, 2013, 11:23:47 AM »
They go back into the 20s & newer. Call them. If you don't get what you need ask for Jimmy Chips...Joe
« Reply #4 on: September 18, 2013, 11:37:26 AM »
Try this:
Iluv69s
« Reply #5 on: September 18, 2013, 02:03:15 PM »
thanks guys...  that PPg color is apparently no longer available in the Deltron(according to the paint rep.) That was my first choice.
i will try that site again and/or call...thanks again.
« Reply #6 on: September 18, 2013, 02:11:51 PM »
If your source says the 'color' is no longer available in deltron..  check another source (maybe another state), OR check online sources?  I haven't checked for ermine while lately, but it's difficult to believe they can't mix it up...
« Reply #7 on: September 27, 2013, 06:45:36 AM »
Ditzler/PPG code 8259 also equates to DuPont 4024-L, if that helps.
« Reply #8 on: September 27, 2013, 10:54:32 AM »
You need to call the PPG library and see if they have formulas on file that jobbers do not. I do it often. Ermine was available in Concept. Or just use another paint company. When painting bikes I sometimes have to use R-M or Glasurit becasue PPG does not have a formula, and time does not allow for a lab match. Once someone has a lab match done, it is entered in their system. Not sure why you want to use BC/CC when shooting a solid color. If additional UV protection is preferred, you can cocktail the last coat/coats of Concept with clear. Black is a different story. SS black shot and then cleared has more depth than BC/CC.
« Reply #9 on: September 27, 2013, 02:29:06 PM »
I totally concur with Sauron's statement...   "Not sure why you want to use BC/CC when shooting a solid color. If additional UV protection is preferred, you can cocktail the last coat/coats of Concept with clear."
This approach will give you the best looking paint possible IMO... :)
