Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
1111263 Delco Remy distributor
« previous
next »
Print
Pages: [
1
Author
Topic: 1111263 Delco Remy distributor (Read 10885 times)
3Zs
Member
on:
September 04, 2006, 02:20:42 PM »
Anybody know the original application for this distributor? It is a tach drive, cast iron, mag pulse with an assembly date of September 26, 1968 and does not appear to be listed in the 1965-1969 "Chevrolet by the Numbers".
Tweet
Logged
Hero Member
Re: 1111263 Delco Remy distributor
Reply #1 on:
September 04, 2006, 05:14:11 PM »
The 1111263 is the highly prized “Ball Bearing” distributor. This was a heavy duty version initially released for the reverse-drive camshaft 427 big block racing engine. It has a special ball bearing on the upper part of the mainshaft instead of the usual bronze bushing. It also has an iron housing with a mechanical tach drive and a special reverse-drive distributor gear that permitted normal clockwise rotation of the distributor in this special 427 engine. It was specified not to have a vacuum advance. (The plate inside the distributor was fixed in position.) This distributor listed for $1,699.05 in the 1991 Chevrolet parts books! I know of several Corvette guys that would love to have a chat with you!!
Logged
3Zs
Member
Reply #2 on:
September 05, 2006, 01:46:39 AM »
Ed, thanks for the information. This distributor was available then only as a "service part" as opposed to being delivered on any particular big block car, (similar to the crossram intake for the small block) right?
Logged
Hero Member
Reply #3 on:
September 05, 2006, 02:20:00 AM »
Correct. It was listed in the Heavy Duty Parts List and available "Over the Counter".
HERE'S
where I got the info from...
Logged
vl99
Newbie
Reply #4 on:
November 16, 2007, 12:30:51 AM »
I have a transistorized distributor the number on the band is 1111263 Delco Remy and it has a 1F3. I also have the box that goes with it and I have a wiring harness for it. I am not sure if I have the coil. I have had these pieces quite a few years. If you are interested in any of this please make me an offer. please email me at tlclark28@alltel.net or call 706-270-0004.
Lamar
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
