Author Topic: Remote Mirror bezel/cable removal??  (Read 5237 times)
« on: August 30, 2013, 10:16:22 PM »
Hey guys,  I could sure use some help/tips from someone who has removed a '69 Camaro remote mirror bezel and cable.   I need to remove my driver side door panel to adjust and lubricate my door glass mechanism, and I cannot see out how to remove the bezel from the remote adjuster; the bezel doesn't seem to fit thru the hole in the door panel.
I'm thinking there MUST be a trick, something I'm unfamiliar with and I do not want to destroy anything.. :)    The only potential means to remove it that I can see is to use pliers to release the cables from the adjuster, but there are three of them, and once released (assuming they will release as I imagine), I've no idea how I would get them back into the correct location.   Pictures attached for reference.   Any help appreciated, and Thanks in advance!
Re: Remote Mirror bezel/cable removal??
« Reply #1 on: August 30, 2013, 10:32:23 PM »
There's a flat head set screw in the bezel itself. Loosen it and bezel will come off. (see picture)
« Reply #2 on: August 30, 2013, 10:37:21 PM »
Here's a better picture.
« Reply #3 on: August 31, 2013, 12:59:51 AM »
FANTASTIC!!  :)    I posted that request, and then went to dinner, come home, and Ed has the answer..  :)
Thank you very much ED!!  :)
