Author Topic: 67 Accelerator Pedal Rod Support  (Read 7830 times)
1967RS/SS
« on: August 30, 2013, 06:02:33 PM »
Is there anything inside the accelerator pedal rod support itself that can wear out or needs replacing other than the two plastic bushings?  Should I replace the entire pedal rod support?
My pedal is low and does not seem to engage the throttle arm at all.  It is at the floor and will need adjusting, but since I need to order the bushings, pedal spring, and pedal to rod pin since they are missing, I would like to get it all at once.
Joe
1967 RS/SS L-48
Van Nuys 01C
Joseph
Re: 67 Accelerator Pedal Rod Support
« Reply #1 on: August 31, 2013, 02:18:39 PM »
Joe
Check the "flat" on both the rod and where it mates with the lever for good engagement without rounding it off and getting sloppy; if that's OK, all it needs is the bushings.
1967RS/SS
« Reply #2 on: September 01, 2013, 04:22:20 AM »
Thanks JohnZ.
Could this be why the pedal doesn't lever or spring back?😠
1967 RS/SS L-48
Van Nuys 01C
Joseph
« Reply #3 on: September 01, 2013, 04:27:44 PM »
<<Could this be why the pedal doesn't lever or spring back?>>
The assembly of the pedal, pivot pin, and spring is shown in UPC 6 in the Assembly Manual - looks like the photo below.
