Author Topic: restoring 69 hood hinges  (Read 15222 times)
DT
« on: August 25, 2013, 02:33:49 PM »
Anyone have a good paint that closely matches the "correct" color of the hood hinges on a 69 ??  I'm not sure I want them plated in Phosphate and have to worry about rust.  Most of the hinges I have seen, look dark grey, not really the phosphate color???  ???
Donny
Re: restoring 69 hood hinges
« Reply #1 on: August 25, 2013, 03:58:02 PM »
These are my original hood hinges (02D '69 Norwood car) that have never been touched except to wipe them down once. The flash makes them look lighter than they really are.
DT
« Reply #2 on: August 25, 2013, 04:39:15 PM »
Wow John, they look brand new!!!  So if I have them plated I shouldn't worry about rust???
Donny
Charley
« Reply #3 on: August 26, 2013, 12:59:57 AM »
Plate them yourself with Palmettos stuff and coat with Wd 40
« Reply #4 on: August 26, 2013, 01:56:32 AM »
« Reply #5 on: August 26, 2013, 03:24:59 AM »
Thank you Cook...  :)
There is some really good information at that link on zinc plating, and clinch riveter, as well as the phosphating article.  These work for Chevroelts as well thunderbirds.  :)
« Reply #6 on: August 26, 2013, 08:15:40 PM »
Anytime.   ;D
I emailed the author about the sodium dichromate solution process.  If he replies I will post up that process.
DT
« Reply #7 on: August 27, 2013, 12:07:17 AM »
Great stuff guys, Thanks!!!
Donny
« Reply #8 on: August 28, 2013, 08:31:41 PM »
I havent heard from the author yet but I did find him on a T-bird website.  Here is what he is talking about on the process of sodium Dichromate..
 Sodium Dichromate
DT
« Reply #9 on: August 28, 2013, 09:39:37 PM »
Which Palmettos is the "correct" finish ???   Manganese or the Zinc??  Manganese solution appears to be charcoal black and the Zinc solution is a medium grey.
Donny
Charley
« Reply #10 on: August 28, 2013, 10:21:09 PM »
I don't remember which one I have used but you can vary the darkness by how long you leave it in the solution. Cheap fun. Buy both a play with it. I also plate a bunch of bolts. Stainless steel salad bowls work great. Do it outside on the bar-b-q so you don't get in trouble in the house. Pour in water, solution, make bolt soup. Pretty easy.
DT
« Reply #11 on: August 28, 2013, 11:56:44 PM »
Thx Charley
Donny
« Reply #12 on: August 29, 2013, 01:19:14 AM »
Do some Palmetto searches and you will find a ton on info! Just phosphate some odds and ends yesterday including a-arm shims (glass beaded the zinc off)! You learn things when you utilize the process like scrubbing the parts with a soft brush and WD-40 to make sure the salts are removed or you will have white spots. I also just tried mystery oil instead of WD-40 and it worked better.
As Charlie mentioned (I agree 100%) buy both and have fun. I just use a cheap hot plate that does not take the solution past 200 degrees F. and stole some old stainless steel pans from the wife's stockpile. :)
montgomg
« Reply #13 on: August 29, 2013, 01:55:37 AM »
I used the medium gray phosphate coating from Palmetto on my 69 Camaro hinges. The color looks just right. You can make the color darker (but not charcoal gray) by leaving the part in the solution longer. I use either WD40 or Rem oil on the treated parts.
After a year no rust on the hinges.
DT
« Reply #14 on: August 29, 2013, 09:04:45 PM »
Thanks guys
Donny
