Author Topic: Holes in choke tower of Holleys? WHY?  (Read 13640 times)
L78racer
Re: Holes in choke tower of Holleys? WHY?
« Reply #1 on: August 23, 2013, 03:51:28 PM »
that was for a rear squirter kit. it used tubes from the front squirter. a way to get a 'double pumper'.
« Reply #2 on: August 23, 2013, 07:15:09 PM »
An example...
« Reply #3 on: August 23, 2013, 07:18:51 PM »
additional squirters was the only possible reason that occurred to me, but I couldn't remember having seen that before (or it had been so long I'd forgotten) *G*   Thanks...
BillOhio
    • photobucket
« Reply #4 on: August 26, 2013, 06:09:11 PM »
Very interesting. I looked at a 70 z that had holes but farther apart. Guy was 3rd owner and someone told him it was a california car and it had water injection at one time to pass smog test.  Thought it was odd
1968 RS 327 4 speed
« Reply #5 on: August 27, 2013, 01:14:30 AM »
Water injection was one of the 'fixes' suggested back in the late 70's for keeping high compression engines running on lower octane fuels.  I briefly considered that and some other 'fixes', before I decided to just park/store my Z28 in 1980...  I even considered conversion to propane, but where do you put a propane tank in a Camaro?  :)
HOT3O2
« Reply #6 on: August 27, 2013, 02:06:13 PM »
If you had a carb with holes drilled in it like that is there any way to repair it and bring it back to normal ?
Rick
69 RS/Z28
L78racer
« Reply #7 on: August 27, 2013, 09:50:12 PM »
Devcon and replate it?
ss jim
« Reply #8 on: August 27, 2013, 11:43:22 PM »
I ran a Holley 780 (3310) with this set-up back in '72-73. I believe I used a Mr. Gasket kit. It also required the use of two meshing gears that bolted to the throttle shafts on the passenger side. Basically when the throttle was pressed all four barrels opened at the same time along with four shots of gas. It ran pretty good after the engine was warmed up. When cold, not so much. Jim
« Reply #9 on: August 28, 2013, 03:18:58 AM »
I'm unsure what Devcon is??  but I'd think you could use one of the low temp mild metal 'welder kits' and weld it up.. grind/sand it down flat, and then recolor it...??  but it would be a lot of work for an 'also ran' carb...
tmodel66
« Reply #10 on: August 28, 2013, 05:16:31 AM »
Why not just buy a double pumper carb to start with?
MyRed67
  • SZZLN 67
« Reply #11 on: August 28, 2013, 06:20:42 AM »
  I think Devcon is very similar to JB Weld.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
MyRed67
  • SZZLN 67
1967 Camaro  LOS  11A
motorman
« Reply #14 on: September 08, 2013, 09:12:40 PM »
I was doing that before holley came out with the four shooter. I have a letter here asking about the fuel volume problem I was having with the pump and they told me I was wasting my time. I ran this setup on AFBs for years before holley became the carb of choice for GM. AFB carbs were not a problem because they had a larger volume pump. they also had a perfect place for the second squirter in the secondary thermal vent. we won a lot of drag races till they caught on as on the holley I drilled the squirter discharge holes in the air cleaner stud boss that squirted into the secondary capped off with a air filter stud.   :D
new Camaros owned 68 and 69 Z-28. new Corvettes owned 59,62,63,64,65,66,97,99 02,05 and 08. retired race engine builder, former NASCAR tech inspector
