Author Topic: which Headlamp retainer is correct for 69 RS ?  (Read 5491 times)
« on: August 19, 2013, 08:25:05 PM »
When I disassembled my front clip and all the RS parts, I noticed the car had two different size (depth) Headlamp retainer rings.   These appear to be identical except for the depth, and both/either work fine.    One is approx. 13/16" deep, and the other is 1" deep.   Which of these are correct?   or did GM use both sizes interchangeably?   One corner of my car was hit before I bought it in the mid 70's, so I'm not sure if both these parts are original from the factory, OR not.  Your help greatly appreciated so I know which of these to replace.. :)   Photos are attached...
Re: which Headlamp retainer is correct for 69 RS ?
« Reply #1 on: December 22, 2018, 05:36:56 PM »
I posted this back in 2013 but got no responses at that time...  I'm hoping someone now can answer this question for me re the headlamp retention rings...  Which is correct?
HOGDADDY
« Reply #2 on: December 22, 2018, 06:45:20 PM »
I was wondering about this before also. I  have a later GM ring that is about 13/16" and I have a repop that is 1" wide.
I am assuming all early first gen Camaro's use the same but I don't know which is correct.
« Reply #3 on: December 23, 2018, 12:59:57 AM »
The thicker one is correct. Never measured an original. I’d say it is every bit an inch if not more(what she said)lol.
« Reply #4 on: December 23, 2018, 07:51:06 AM »
Bentley your wit is only matched by your knowledge...(made me laugh with that one). Good to see you checking in.
« Reply #5 on: December 23, 2018, 10:54:33 AM »
Thanks A.
