Author Topic: 1967 Rally Sport Relay Board  (Read 5386 times)
onlythebestbuys
« on: August 07, 2013, 11:44:27 PM »
I have a 67 rs/ss conv....just bought rs wiring harness....think i need to buy the relay board also....I have no idea where it actually mounts....wiring is there through the driver's fender, but I really need to know where the original mount with 3 relays and circuit breaker mount to.  I have looked at many pix to no avail...please help!!!
Charley PHX
Re: 1967 Rally Sport Relay Board
« Reply #1 on: August 08, 2013, 02:28:34 AM »
Goes under the left front fender, in front of the wheelhouse, tucked up underneath fender.  An original RS LF fender will have 2 bolt holes for mounting the relay bracket.  When installed correctly all you will see are the 2 bolt heads.  The board & the wiring all tuck up underneath.
'67 04D (LOS) L-35/M20 (-L181A) Convertible (owned since 1975) - Bow Tie 981/1000 GOLD (July 2023)
'67 06D (LOS) L-78 Coupe (body) (1979 barn find) - Traded 2018 to my car builder!
big iron
« Reply #2 on: August 29, 2013, 03:02:27 AM »
Charley,
What color is the plastic wire clip that goes in the 3rd hole from the front?
What type head markings do you have on your 2 bolts?
Bob
