Author Topic: 1969 OEM AM antenna question.  (Read 20344 times)
Re: 1969 OEM AM antenna question.
« Reply #15 on: August 08, 2013, 02:09:36 PM »
My Original 08C am antenna mast does not have a grove. Maybe it was a vendor change mid year?
Mine's original too (02D car) and doesn't have the tip groove.
69Z28
  • 69 X33D80 Z28
« Reply #16 on: August 08, 2013, 02:34:28 PM »
Can we assume different vendors then? This would make identifying who manufactured it if there was an issue wouldn't it?
GaryC
« Reply #17 on: August 08, 2013, 03:21:10 PM »
Because of your questions on the Camaro AM antennas, I pulled my parts out yesterday and took some photos:
antenna mast tip, antenna mast lower end with other parts,  mount and retainer from lower side with PNs, antenna connector showing 'chevy bowtie script'.  I could not find a PN on the mast itself, nor on the cable connector, but mine had an A-1 on the side opposite the bowtie emblem.  PN on the base (which fits against the fender) is:   3937665.   The pn on the lock wasn't entirely legible, but might have been 3943655.
« Reply #18 on: August 08, 2013, 03:23:15 PM »
and shown below is the assembled view.   The 'collapsed length' of my antenna is 18" from tip to the top of the retainer nut.
« Reply #19 on: August 08, 2013, 04:22:23 PM »
great pictures Gary. Very detailed. I wish I had your resizing skills
Mark
« Reply #20 on: August 08, 2013, 04:23:25 PM »
My original AM mast from my 04L Norwood built car has a groove in the top ferrule.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
69Z28
  • 69 X33D80 Z28
« Reply #21 on: August 08, 2013, 04:30:11 PM »
The mast I bought has the same plain tip as in Gary's first pic.
GaryC
« Reply #22 on: August 08, 2013, 04:42:44 PM »
Hi Austin,  well.. it's not MY resizing skills, it's done by the Light Image Resizer software, recommended on this site by JohnZ many months ago, and which I tried and liked, and ultimately purchased.   It's quick and easy and does retain outstanding detail in very small file sizes.   After taking my higher resolution image, I first run it thru Paint to clip out the portion I want to post, then use the Light Image Resizer on the clipped portion.   You can repeat the process with lower detail until the file size fits the CRG requirement.   I think the images I posted this morning were 100kb or less each...   Try it.. you'll love it too! and we'll get to see more photos of your car too! :)  you can download and use it for free, but after several uses, it gets *slower* unless you purchase it.. :)    For $20-30 it's great.
http://www.obviousidea.com/windows-software/light-image-resizer/
And thanking JohnZ again for recommending it previously!  :)
