Author Topic: Part Number Stamp or Sticker on Wiper Motor Assy  (Read 133980 times)
Re: Part Number Stamp or Sticker on Wiper Motor Assy
« Reply #45 on: January 21, 2015, 12:04:17 AM »
stamped ,as you know ( don't have to pull the part out of storage for this one ,LOL) side note...car's never been in the rain or snow( at least since 76 ,and reported prior...it was always a toy) Honestly I don't know if the wipers work because I've never seen them operated ! It'll get a bench test before reassembly.
« Reply #46 on: January 21, 2015, 08:41:24 AM »
you just looking for 69's ?
Yup, as far as I know, the 68's all used a stamped part number, 5045441 for non-RS (and I don't recall the RS version part number off the top of my head). Am not aware of a date code on them, although I have seen some ink-stamped numbers on certain motor casings; maybe the next member research effort?
« Reply #47 on: January 21, 2015, 08:45:11 AM »
My all-original 02D non-RS '69 has the mylar sticker with the part number, and the motor is stamped Delco Products.
John, looks like yours is stamped from Rochester NY, not Dayton OH; if you could confirm the assembly date code on the sticker, that'd be a solid data point, as your car is so original.
« Reply #48 on: January 21, 2015, 01:43:24 PM »
The early ones I've looked at had yellow ink stampings with the Julian day and year but yes a different project! :)
« Reply #49 on: January 21, 2015, 08:30:33 PM »
Thanks Chick!
« Reply #50 on: January 23, 2015, 05:17:06 PM »
The sticker says "5045572  036 9 B F"  (that's February 5th, car was built February 27th).
« Reply #51 on: January 23, 2015, 07:21:35 PM »
I'm only trying to add JohnZ's data, but having mucho trouble with the table formatting..  Could someone who knows how to do this in the cRG s/w please correct it?  :)
build   NOR      RS?          sticker          Stamped      Sticker            (Notes)
date    LOS      Not?           PN?              PN?           codes
10D      LOS        RS    5045608                                          RS solenoid dtd 10-28-68
11D      NOR     RS                         5045605
12B     LOS      RS                          5045605            stamped - 4918976 2
??      NOR   non RS                         5045572   034 9 B E
02D     NOR   non RS                           5045572     036 9 B F      Rochester
03B     NOR   non RS   5045572                      053 9 6 A
03D     NOR     RS    5045605                      079 9 B F       Part # in yellow paint
06A     NOR   non RS                           5045572   100 9 5 B
06A     NOR   non RS                          5045572   134 9 6 B
07A     NOR   non RS                          5045572   170 9 6 B
09C     NOR     RS    5045605                       227 9 6 A        Dayton
??      NOR   non RS   5045572                       282 9 6 B
« Last Edit: January 23, 2015, 07:41:55 PM by 69Z28-RS »
« Reply #52 on: January 24, 2015, 04:33:28 PM »
11D    NOR       RS      5045605
???     NOR   non RS      5045572        282 9 6 B
I tried -
« Reply #53 on: January 24, 2015, 05:39:30 PM »
Steve,  you did better aligning the values than I did, but some of the PNs were *stamped* in the metal as opposed to printed on a sticker.  I've got it organized in WORD, as well as EXCEL, but I can't figure out how to 'paste' it into a reply here on CRG....   ???
« Reply #54 on: January 24, 2015, 08:52:12 PM »
11D    NOR       RS                            5045605
I tried - again
« Last Edit: January 24, 2015, 09:20:47 PM by z28z11 »
« Reply #55 on: January 24, 2015, 09:15:47 PM »
^ Thanks to Steve and Gary for updating the table - I had the same issues previously, seemed to be trial and error as it often looked different between the editing screen (aligned well) and when posted (jumbled up).......
Darrell kindly put it into a spreadsheet, but unless the spreadsheet can be posted here, we'd have to rely on him, or someone with a copy, updating it and posting a screen grab of it.
I'll look into how to create tables in HTML code.
« Reply #56 on: January 25, 2015, 01:20:32 AM »
Toss the spreadsheet on Google Drive.
« Reply #57 on: January 25, 2015, 05:42:44 AM »
Not familiar with that Kurt but will check it out - thanks!
« Reply #58 on: January 26, 2015, 02:46:44 AM »
« Reply #59 on: January 26, 2015, 03:00:47 AM »
We were actually TRYING to SHOW the spreadsheet data HERE, Kurt...   :)   not drop a link for everyone to find.. :)
oh.. and aren't you an 'old fart' too?  :)
