Author Topic: Upper control arm  (Read 9865 times)
My68SS
Upper control arm
« on: August 31, 2006, 09:39:55 AM »
Just wondering about the significance of the two holes in the side of the arm. My original 68 arms don't have them.
The arm is supposedly NOS 69 camaro.
Also, the shape of the support bar is different, the loose one in the pic is of my 68. The one attached to the arm has a number cast into it, which as best as I can make out reads 381904.
Is that a 69 casting number?
Is the loose one the correct shape for 68?
« Last Edit: April 23, 2015, 04:33:39 PM by KurtS »
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
crossram
  • Guest
Re: Upper control arm
« Reply #1 on: August 31, 2006, 11:42:19 AM »
I think the two holes are for mounting a clip to hold the brake flex hose used in 69.
CNorton
« Reply #2 on: August 31, 2006, 09:14:15 PM »
Correct on the two holes.  They're to mount the clip on the front disc brake flexible line.  Every stock Camaro I've ever taken apart had the cross shafts like the loose one.  I've never seen one of the others.
c
Mark
« Reply #3 on: August 31, 2006, 11:45:58 PM »
Is that a rubber bump stop in the middle of the control arm in the top picture?  If so it's not from a Camaro.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
RamAirDave
    • TheMuscleCarGuys.com
« Reply #4 on: September 01, 2006, 02:08:34 AM »
Camaro has a rubber bump stop in the upper control arm  The Abodies have the bump stop on the frame.
The cross shaft in the control arm is a replacement, the original is the loose one.
www.TheMuscleCarGuys.com
My68SS
« Reply #5 on: September 01, 2006, 08:46:16 AM »
Thanks for the replies  :)
Quote
So replacement shafts came from a different foundry?
The other odd thing is that the rubber bump is not a 'push-in' type, it has a thread and nut holding it in, like the bump on the lower arm.
Is a bolted in upper bump correct for 69?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
CNorton
« Reply #6 on: September 01, 2006, 12:44:44 PM »
Never seen one attached that way.  They're all "push in."
RamAirDave
« Reply #7 on: September 01, 2006, 10:36:28 PM »
The replacement cross shaft looks like (or at least very similar) those that come in new PST front suspension kits.  They may be included in/from others, I dont know for sure.
The upper bump stop should be a push in type.
dave
My68SS
« Reply #8 on: September 02, 2006, 03:17:18 PM »
Quote
dave
Agreed
Here's a pic of the bump, must be from some other car as it's a poor fit in the hole [way too small]
Quote
Here's a close up of the numbers on the odd shaft, reads 381904 GM 40
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #9 on: September 03, 2006, 06:47:16 AM »
Looks like a pinion bumper.
