Author Topic: Exhaust heat valve question.  (Read 21698 times)
69Z28
  • 69 X33D80 Z28
« on: July 24, 2013, 04:01:08 AM »
Is the heat valve the same for all 69 small blocks with 2" and 2 1/4" headpipes or are there two different valves? What about flanges? I don't have them and need them. Found both a valve and 2 flanges but need to make sure they will fit the factory manifolds and exhaust for a 69 DZ engine.
GaryC
69pace
    • TeamCamaro - Moderator
Re: Exhaust heat valve question.
« Reply #1 on: July 24, 2013, 04:26:52 AM »
http://www.rickscamaros.com/1969+chevy+camaro+standard/camaro-exhaust-manifold-heat-riser-assembly-small-block-gm-1967-1974.html
This is the only one I know of for 1969 small blocks...though most of the ones I have seen were removed and an eliminator ring substituted or they just gutted and reinstalled the factory item by removing the flapper door and weights and a stove bolt inserted to close former axle pivot hole.
69Z28
  • 69 X33D80 Z28
« Reply #2 on: July 31, 2013, 10:50:01 PM »
This is the heat valve I have. Looks the same doesn't it? Something is either upside down or backwards on mine I think.
GaryC
69pace
« Reply #3 on: August 01, 2013, 04:20:48 PM »
Yeah the bottom picture looks right side up as the weight should be installed on the fender side, weight pointed toward the front of the vehicle. Take the top one and flip it around and see what it looks like. Both Look in good condition considering age.
69Z28
  • 69 X33D80 Z28
« Reply #4 on: August 01, 2013, 05:14:07 PM »
Those 2 pics are of the same valve. Works perfect, just need to clean it up a bit. So as it sits in the second pic just rotate the valve 1/4 turn clockwise so the weight is parallel with the fender.
Is the Ricks pic wrong?
GaryC
« Reply #5 on: August 02, 2013, 04:36:31 PM »
Nope, it's just shown upside-down; the flat side goes up, against the (flat) outlet flange on the manifold, with a gasket, and the chamfered side goes down, and mates with the top of the "donut".
69Z28
  • 69 X33D80 Z28
« Reply #6 on: August 02, 2013, 04:43:29 PM »
If you look at the pic of Ricks and mine the weigh mechanism is reversed or backwards or something. One of them is wrong it believe.
GaryC
rich69rs
  • LF7/M35/Z22/Z87
« Reply #7 on: August 02, 2013, 04:55:23 PM »
These things are problematic at best - I have not had
a good experience with any current offerings.  For what it's
worth, my two, cents is that they will eventually stick, and
probably in the closed or partially closed position.
I removed them from both my '66 Chevelke and '69 Camaro
and replaced them with the donut replacements.
Unless you absolutely have to have it original, to me
the problems far outweigh the benefits.  Both of my
cars start easily - and I give them a few extra seconds (10-15) at
idle when I first start them, but other than that you would not
know the heat riser valves weren't installed unless you physically
went and looked.
Richard Thomas
1969 RS
69pace
« Reply #8 on: August 02, 2013, 08:52:39 PM »
No its the same valve - as JohnZ states there IS a top side and a bottom side of the valve.  And yes it was common practice to remove or to gut the valve, and close the hole from the removed flapper axle with a standard nut and bolt. That was what was done on my vehicle by the original owner when he removed the smog pump.
69Z28
  • 69 X33D80 Z28
« Reply #9 on: August 02, 2013, 10:07:38 PM »
Maybe your not seeing what I see. On the Ricks valve pic, the bevel for the packing donut is facing up with the weight mechanism pointing, lets say north and on the right. If you look at my second pic the flat gasket side is up with the weight mechanism pointing north and to the right. If I flip mine over 180 then the weight mechanism is on the left of the valve whereas the Ricks pic is on the right...OR...if you spin my first pic 180 either way, clockwise or counter-clockwise to match the Ricks pic the weight mechanism's are opposite.
Can you see it? I'm thinking one of these is wrong.
GaryC
69pace
« Reply #10 on: August 03, 2013, 02:38:57 AM »
No I understand what you are saying but there are many repro valves out there some are flat and chamfered as original, others are chamfered on both sides. ANd they pictures are generic-interchangeable on catalog listings.
69Z28
  • 69 X33D80 Z28
« Reply #11 on: August 03, 2013, 07:48:49 PM »
OK, I think I got it now. That pic in itself is not a good representation of what an OEM heat valve would look like for a 69 Camaro Z28.
If that's the case does mine look correct? I think the guy said it was a take off of a 71 350 270hp Corvette.
GaryC
69pace
« Reply #12 on: August 04, 2013, 02:41:09 AM »
Yes I believe that John liked your examples.
mickeystoys69RSSS
« Reply #13 on: August 06, 2013, 12:36:43 AM »
Any way to tell if this valve is stuck? The more I think about it, I noticed that at the rear tips the exhaust flows better on the drivers side than passengers. So I am thinking mine might be stuck?
« Reply #14 on: August 06, 2013, 01:25:40 AM »
OE from my 68 Z
