Author Topic: 1967 RS  (Read 27505 times)
67rs327
Re: 1967 RS
« Reply #15 on: July 26, 2013, 02:05:16 PM »
No tach, gauges, or PS on the POP. Only items listed are a.m. radio, telescoping antenna, folding rear seat, and single rear speaker - all of which the car has.
1967rs L30/M20 Bolero Red - LOS 11A.
Chris - New Hampshire.
MyRed67
  • SZZLN 67
Re: 1967 RS
« Reply #16 on: July 26, 2013, 07:59:21 PM »
Maybe someone more knowledgeable about the POPs will chime in, I would think those items would be on the POP.  At any rate nice options.  Another thought I had, was maybe the car was sitting on the lot somewhere minus those options, the first owner liked it and had the dealer install those.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
1968 Z28
Re: 1967 RS
« Reply #17 on: July 27, 2013, 12:57:16 AM »
This link has the listing of the options on the POP.....
     http://www.camaros.org/numbers.shtml#POPCodes
« Last Edit: July 27, 2013, 01:30:00 AM by 1968 Z28 »
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Steve Barndt
Re: 1967 RS
« Reply #18 on: July 27, 2013, 01:42:17 AM »
I am curious about not having 4P showing up earlier then November. I have a 10E with a 4P on it. I've had it since 12/68 and know where it was before then.
Re: 1967 RS
« Reply #19 on: September 30, 2013, 05:09:12 PM »
http://www.camaros.org/numbers.shtml#67Codes
MyRed67
  • SZZLN 67
Re: 1967 RS
« Reply #20 on: September 30, 2013, 08:58:00 PM »
OK,,no to Tach. and Gauges on the P.O.P., but think it would be on the Trim Tag.  P. Steering should be on the P.O.P. unless it was Dealer installed.  That was done quite a bit I'm told.
1967 Camaro  LOS  11A
ozman
Re: 1967 RS
« Reply #21 on: September 01, 2014, 11:27:36 PM »
I too have a 67 L30- M20 late 67 start build date June10th.It does have the 4P code with date code engine close to cowl,may 25 stamp.Strangely it has LS on the cowl tag instead of LOS which I've seen online others built the same cowl day 06B.  J 177 ( June 10th),It has the square radius rod to stabilize the 12 bolt rear end I'd send pic but don't know how
06B.                  J177
67-12437.  LS-37029
760-Z.              H-H
L.  2LGR     3DL
4P
67 rs L30-M20
LS 6B Mountain Green
4P
Re: 1967 RS
« Reply #22 on: September 02, 2014, 12:49:51 AM »
It has the square radius rod to stabilize the 12 bolt rear end I'd send pic but don't know how.
Read this...  http://www.camaros.org/forum/index.php?topic=7809.0
Re: 1967 RS
« Reply #23 on: September 02, 2014, 02:34:13 PM »
Cowl tag only had information that was meaningful to Fisher Body, and nobody on the Chevrolet side paid any attention to the cowl tag; tach and gauges were installed by Chevrolet.
ozman
Re: 1967 RS
« Reply #24 on: September 03, 2014, 01:33:29 PM »
wish i had the pop for mine.It too is the 67 rs L30-M20 with the factory tach ,4 speed,console with gauges with fold down rear seat and rear speaker.The cowl tag shows fold down rear seat,4 speed floor shift,console,rear speaker,courtesy lamp,rally sport and 4p code wich relates to ss options
67 rs L30-M20
4P
ozman
Re: 1967 RS
« Reply #25 on: September 05, 2014, 02:25:01 PM »
according to what im reading on crg,the 4P code was not put on the cowl tag for L30-M20 cars until dec-jan mid year.So any cars built with date code 08-12 which were built in 66 and maybe 01 built in 67 would not have the 4P code.Code 01-07 would
67 rs L30-M20
4P
