Author Topic: Big Block Distributor Hold Down Clamp  (Read 30095 times)
1968 Z28
Re: Big Block Distributor Hold Down Clamp
« Reply #30 on: July 19, 2013, 04:59:07 AM »
My 1968 07C Z28 has a engine build date of 0619.  It is already on the list....just need to add build date if you do decide to do so.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #31 on: July 19, 2013, 02:07:54 PM »
Update:
Year    Engine    Engine Date   Body Date     Clamp Type
67         L30                          610B               Wire
67         L35         0214          704B               Stamped
67         L35         0308          705B               Stamped
68         Z28                          801B              Wire
68         L35         0321          805C              Stamped
68         L78                          806?               Wire
68         Z28         0619          807C              Stamped
« Reply #32 on: July 19, 2013, 05:15:41 PM »
Update:
67         L30                          610B               Wire
68         Z28                          801B              Wire
68         L78                          806?               Wire
Ed, per my earlier post our 01B built 68Z engine was assembled 12/21/67.
« Reply #33 on: July 19, 2013, 05:33:07 PM »
Update:
67         L30                          610B               Wire
68         Z28         1221          801B              Wire
68         L78                          806?               Wire
rare396bronze
« Reply #34 on: July 25, 2013, 04:18:24 AM »
06a L35 & 06b 327/210 hp stamped brackets
« Reply #35 on: July 25, 2013, 11:06:30 AM »
What years and motor assembly dates?
67 RS Ragtop
« Reply #36 on: July 25, 2013, 06:05:27 PM »
My 67 L-30 (610B, with wire) has an engine assy date of 0812 if you would like to update.
« Reply #37 on: July 25, 2013, 06:35:31 PM »
Update (07-25-13):
67         L30         0812          610B               Wire
68         L35                          806A              Stamped
68         LF7                          806B               Stamped
68         L78                          806?               Wire
« Reply #38 on: August 01, 2013, 01:59:49 AM »
68         L35         1215          812E              Wire
Steve68
« Reply #39 on: August 01, 2013, 05:41:47 PM »
I researched this some.  My parts history book shows the 3772532 wire clamp was to be substituted with 3704912 starting November 1969.  The October 1, 1967 P&A 34 shows 1964-1968 all (8 cyl) clamp unit 3772532.  The October 1, 1970 P&A shows 67-70 3704912 for all 8 cyl.
1968 Z28
« Reply #40 on: August 01, 2013, 06:34:31 PM »
My July 1969 Camaro Master Parts Catalog shows this:
     2.363  Clamp Unit, Ignition Timer Distributor
               1     3772532     1967/8  CYL
               1     3704912     1968-69/8  CYL
A 2-15-69 P&A 34 shows:
               1     3772532     64-67 All 8 CYL
               1     3704912     68     All 8 CYL
Jerry G.
1969L89JEFF
« Reply #41 on: August 07, 2013, 02:38:09 AM »
12A 1968 build date  L89. Stamped hold down, no finish.
monaroman
« Reply #42 on: August 23, 2013, 10:52:55 PM »
Hi there,
Looking to purchase a GM stamped style distributor bracket.
Does anyone have a accurate photo front and back of the stamped style bracket?
What was the bolt marking?
Thank you.
1968 Z28
« Reply #43 on: August 24, 2013, 05:10:19 AM »
This one is from my 1968 Z28....There is a possibility that different years might have different bolt heads.
Bolt Head
Bolt Lengthwise - 1 1/8" by 3/8"
Clamp - up side
Clamp - Down side
Jerry G.
