Author Topic: spoiler hardware  (Read 15137 times)
sbmiano
spoiler hardware
« on: July 09, 2013, 01:32:29 AM »
What is the correct hardware for the rear spoiler on 69 z28.  Getting different answers an y.net pictures?
69 z28  Van Nuys 04D Legends Certified
09 viper 5k miles
Re: spoiler hardware
« Reply #1 on: July 09, 2013, 05:26:27 AM »
Scott,  I'm unsure when the changeover happened, but the late '69 Z28's used a special flanged stud and nut with built in washer and rubber..  I think '68's used the acorn style, and probably early '69's?   the unrestored blue/white car like yours was a May '69 car and had the flanged stud and washered nuts..  I can't recall what month your car was??
« Reply #2 on: July 09, 2013, 03:15:29 PM »
My all-original 02D Norwood '69Z has acorn nuts along the rear (outside the weatherstrip, no sealer required), and flanged nuts with integral sealer along the front; if you look closely, you can see black sealer tape through the un-used hole for the standard trunk lid emblem.
« Reply #3 on: July 10, 2013, 05:34:19 PM »
the later style on my 08C uses nuts instead of the acorn style on Kurts car. I also noticed that mine uses different studs. Unfortunately I suck at resizing my pictures. I think mine are the same as Gary's , so Gary can you post a picture of yours? I think your studs will look similar to mine
« Reply #4 on: July 10, 2013, 09:39:07 PM »
Bullitt,
Yes, I believe yours and mine are the same, and also the same as on all the late  '69 Legends cars I observed at the nationals last week.  The same nut type was also on the unrestored '69 Z28 (blue/white) - a May'69 car.
Attached are a few photos:
photo1) the rear-most nuts as originally installed for holding the spoiler.
photo2)  the 7 original nuts from removing my spoiler for cleaning and repair (one of the longer forward-studs was broken and the nut was missing),
and
photo3) one of the longer studs from a fwd spoiler position with the flange and two differing thread types.  What made the studs unusual was the existence of a 5/8" diameter 'flange' in the middle of it's length, with machine thread studs on one side of the flange, and a self threading type thread on the other side (for installing into the spoiler itself).     Note:  the rear-most studs were similar to the forward ones, although with shorter machine threads on the 'nut' side.
« Reply #5 on: July 10, 2013, 10:20:32 PM »
Thats exactly what I have on my car, thanks Gary your the wiz with resizing your photos. Now when I look at your original stud it doesn't have the taper and spacing that John Z stud does. So different studs and nuts for early cars? John could your studs and nuts have been over the counter replacements?
sbmiano
« Reply #6 on: July 11, 2013, 02:24:01 PM »
What is considered an early and what is considered late build?  I have an 04D which I think falls in the maybe its this way and maybe its that way do to the build date? lol  I have the acorn type on the front and shouldered washers on the back and lost points at legends.
09 viper 5k miles
« Reply #7 on: July 11, 2013, 02:50:43 PM »
hi Scott,
What did the judges say about your hardware?   Can you photograph it as it is and provide the photos and what the judges told you?  JohnZ's original 02D if I recall, has the acorn nuts on the four rear-lip studs for the rear spoiler, whereas the blue white unrestored Z (05B or 05C?) at the Frederick nationals had the nuts same as my and other later '69 cars I have seen and noted at the nationals.   yours is in the middle of the data points I have, so it 'might' be either way? or it's also possible that the factory had some 'leeway' in what to use, and which was used was somewhat arbitrary?   The rear spoiler was installed in the Fisher plant, and I'm unaware of any factual documents for that (such as we have in the factory assembly manual for what was *supposed* to be done in the assembly plants...  Provide some photos of yours and give us the judges statements and points, and maybe we can all learn something?
« Reply #8 on: July 11, 2013, 02:53:00 PM »
Nope - it's never been touched since the day it was built; it was among the last of the '69 cars that got the "short" '68-style rear spoiler.
hubleyman
« Reply #9 on: July 11, 2013, 04:01:46 PM »
Sounds like you guys should do one of your famous time frame / parts info research charts specifically on rear spoiler hardware.....
If you do, allow me to add the details from my mostly unrestored 1969 Z.  It's a 10A of '68 short spoiler NOR car with hardware just like Johns 02D car.
Charlie
« Last Edit: July 11, 2013, 05:17:23 PM by hubleyman »
« Reply #10 on: July 11, 2013, 05:59:03 PM »
It might be interesting also to check on 'short' versus long spoilers at the same time...  perhaps the earlier hardware was used with the short spoilers, and the changes made at the same time?...
Charley, do you have a photo of the 'end' of one of the longer (fwd) studs?   see if it's like JohnZ's or like the later ones?
sbmiano
« Reply #11 on: July 11, 2013, 06:02:01 PM »
I will take photos this weekend and post.  I have the longer spoiler on my car.  Thanks for the help
09 viper 5k miles
hubleyman
« Reply #12 on: July 11, 2013, 08:54:13 PM »
The studs on my spoiler are the stepped down style just like Johns...  Charlie
« Reply #13 on: July 12, 2013, 08:11:44 PM »
In the plant, that end treatment (small unthreaded tip on studs or bolts) was called a "dog-point".
sbmiano
« Reply #14 on: July 17, 2013, 01:35:15 PM »
so the million dollar question is what hardware belongs on an 04D car?  Acorn style on the front and the shouldered ones on the back?
09 viper 5k miles
