Author Topic: 69 camaro multi leafs or mono  (Read 24730 times)
GS STAGE 1
« on: August 30, 2006, 01:01:40 AM »
Is there any chance my 327 2 bbl car came with multi leafs from the factory?
I read under suspension.......that all 12 bolts and 350 cars had them, but are there any cases where a 327 cars came so equipped?
GS STAGE 1
Re: 69 camaro multi leafs or mono
« Reply #1 on: August 30, 2006, 01:02:41 AM »
pic 2
« Reply #2 on: August 30, 2006, 02:06:14 AM »
About zero. Every 327 I've seen has monoleafs.
What is in the first box on line 4 of your car's BBC? I can't read it, but if you can, that should confirm it.
GS STAGE 1
« Reply #3 on: August 30, 2006, 02:39:10 AM »
Kurt, it appears to be an "I" or a "T"
GS STAGE 1
« Reply #4 on: August 30, 2006, 02:58:06 AM »
Couple more questions........
1) I just bought a 69 rear-(sept date) that was advertised as a multi leaf. When put side by side with a 76 multi rear, the spring pads are 1/4 inch smaller than the 76 rear, is this common with the later rears?
2) Is there any advantage of running the multi leafs, especially on a non performance car?
« Last Edit: August 30, 2006, 03:01:01 AM by GS STAGE 1 »
GS STAGE 1
« Reply #5 on: August 30, 2006, 03:01:54 AM »
pic 2
hotrod68
  • almost finished
« Reply #6 on: August 31, 2006, 03:04:49 AM »
Dunno about '69s, but according to my GM books, any '68 Camaro 327 over the base 4bbl engine (327/250hp) should have had multi-leafs, and that also meant it had a 12-bolt, but they were rare as hen's teeth. No 2-barrel 327s seem to have had multi-leafs. I've seen a 327/275hp 4-speed '68 with a 12-bolt and multi-leafs, but only 1. Every 2bbl car I've ever seen had mono-leafs, '68 or '69. I guess it's possible, though.
RamAirDave
    • TheMuscleCarGuys.com
« Reply #7 on: August 31, 2006, 04:01:15 AM »
Those spring clamps dont look like the factory ones.  The originals I've seen have always had a type of rivet head holding them.  Leads me to believe they arent the originals.
Unless this type was available also?
dave
www.TheMuscleCarGuys.com
rich69rs
  • LF7/M35/Z22/Z87
« Reply #8 on: August 31, 2006, 05:26:27 AM »
I would concur with Kurt that your 327/210 hp; 2Bbl small bore Rochester carb almost certainly had monoleaf springs from the factory; as is the case with my '69 RS with the same engine and carb.  (Also true for base 307's in later '69 production.)
The monoleaf spring rides very well - don't believe you'll be disappointed if you go that route.
« Last Edit: August 31, 2006, 05:34:18 AM by rich69rs »
Richard Thomas
1969 RS
GS STAGE 1
« Reply #9 on: August 31, 2006, 11:36:53 PM »
pic
GS STAGE 1
« Reply #10 on: August 31, 2006, 11:58:21 PM »
Is there any place on this site that breaks down the body broadcast copy??
« Reply #11 on: September 04, 2006, 05:27:04 AM »
Yup, probably a T...... and then another letter. :) Probably TN or TM. Might be tough to tell those apart.....
Greg69gg327
« Reply #12 on: September 15, 2006, 06:40:15 PM »
I have one of the early model California made 69s 327/210 hp; 2Bbl small bore Rochester carb. 77900 original miles. It has mono leafs.  Don't know if this helps much but a sample of one.
cheers,  Greg
chevysscamaro68
« Reply #13 on: September 18, 2006, 02:21:36 AM »
I own a 1968 , I have a 10 bolt rear end w/ multi leaf springs.  I do not know if the rear end is original to the car or not.
« Reply #14 on: September 18, 2006, 03:43:38 PM »
The multi-leaf springs in the photo are aftermarket replacements; factory multi-leaf springs looked like this:
