I had asked a question a couple of weeks ago about how to correctly position a '68 rear wheel opening molding on a reproduction fender with no molding screw holes drilled in it for reference. I got the answer I needed but now am wondering about a couple of other things. I was told the front edge of the molding should stop like this for a non Rally Sport.
And the rear edge should go all the way to the bottome of the opening like this.
My first question is this. The picture below is a '67. Look at the bottom of the forward edge of the molding and how far it goes down and how it conforms the the shape of the body. This is different from my '68 GM molding. So is this a " '67 only " molding and wrong for a '68?
This is a picture of the rear bottom edge of my GM passenger side molding held up near my rear wheel opening. My quarter panel is a reproduction. The shape of the bottom of the molding does not match the shape of quarter panel here. In fact, when you put the molding on and line it up with the bottom of the opening, there is no metal behind the screw hole in the molding.
Is the quarter panel not shaped right here?
Thanks....Dave
