Author Topic: '68 Standard gas cap fitment problems  (Read 10651 times)
DAVEN1256
« on: July 02, 2013, 12:31:12 AM »
I am trying to find just how close a '68 standard gas cap should follow the contour of the tail panel.
I have a a reproduction tail panel. When I put my original filler tube and gas cap on, the fit was terrible. I attributed at least part of the problem to the fact that the flange on my original filler tube was out of whack. The angle of the flange to the tube wasn't consistant all the way around. I am sure the fact that the tail panel is a reproduction has something to do with it too.
I bought a new filler tube and gas cap from CHQ. The fit is better but the cap still sticks out a little at the top and about a 1/8 or 3/16 inch on the bottom. It stuck out a little on the sides but I was able to put a little pressure on the sides of the cap and bend it a little so that the side are fairly flush with the tail panel.
So my questions are:     Were these gas caps completely flush with the tail panel all the way around when they left the factory or did they stick out some?
                                   If they were flush, what can I do to get a better fit?
The attached photos are of the new cap. The second photo is from the top looking down. I could not get it to orient the right way.
          Thanks......Dave
Re: '68 Standard gas cap fitment problems
« Reply #1 on: July 02, 2013, 11:56:35 PM »
That's how mine looks.
lakeholme
  • 68-12D L30/M35
« Reply #2 on: July 03, 2013, 03:52:58 PM »
X2
DAVEN1256
« Reply #3 on: July 10, 2013, 01:30:37 AM »
68Zproject and lakeholme........are your tailpanels and gas caps original to the car, GM replacements, or reproductions ?
lakeholme
  • 68-12D L30/M35
« Reply #4 on: July 10, 2013, 12:19:17 PM »
Tailpanel is original. Not certain of cap, but I've subsequently replaced the cap with a repo at restoration and the fit is the same. My observation about 68 standard caps is they fit but not always perfectly flush and tight.
DAVEN1256
« Reply #5 on: July 10, 2013, 12:59:35 PM »
If I can't get mine fitting any better, at least it's good to know I am not alone and that the originals might not have been much better.
                     Thanks......Dave
jeff68
« Reply #6 on: July 10, 2013, 02:18:24 PM »
I agree that the cap contour doesn't match the tail panel, but you're planning on getting the cap centered in the opening, correct?
DAVEN1256
« Reply #7 on: July 10, 2013, 06:52:27 PM »
Yes I am...... The centering of the cap is not as bad as it looks in the picture. The angle I took it at and the flash caused a shadow making it look more off center...... I will adjust it to get it better though.
« Reply #8 on: July 15, 2013, 11:23:17 PM »
My tailpanel is original and the cap was an NOS one.  Mine looks just like your as far as sticking out a little.  I had a 68 ss and its cap fit that way too.  My issue with the repop was that it didn't fit tightly on the gas tube.  The NOS one is tight.
DAVEN1256
« Reply #9 on: July 16, 2013, 01:31:22 AM »
Thank you for the info.......Dave
