Author Topic: Muncie Transmission ID  (Read 7853 times)
jcole541
« on: June 24, 2013, 02:39:43 PM »
The Z 28 we bought came with an engine and transmission in it that we are in the process of pulling.  I'd like help in identifying the transmission.  Case # 3885010, date stamp P0302.  Transmission has the original tag still on it # 9784425.  Any info you have would be greatly appreciated.  Thank you
Re: Muncie Transmission ID
« Reply #1 on: June 24, 2013, 02:48:09 PM »
3885010 is a 66-67 main case and P0302 indicates a March 2nd, 1966 assembly date. However, recheck the 9784425 tag. There's no such number.
jcole541
« Reply #2 on: June 24, 2013, 03:17:41 PM »
I'll jack up the car and take another look.  The bolt is covering half that # but it sure looks like a 9.  I will try to get a picture.
jcole541
« Reply #3 on: September 07, 2013, 04:49:44 PM »
Finally took transmission out of the car.  The main case is 3885010, the tail piece is 3846429, the side cover is a 3884685, the small tag attached to the side cover is 9784425.  Now that the transmission is out there is a # stamped across the top that I can see.  It is a larger font.  250765.  If you would like to see any pictures let me know.  Any help to identify this would be appreciated.
John
rodent
« Reply #4 on: September 07, 2013, 10:07:47 PM »
« Reply #5 on: September 08, 2013, 12:24:19 AM »
Had a Chevelle with that tag #.
« Reply #6 on: September 08, 2013, 04:59:04 PM »
I've seen Pontiacs with the 429 tailhousing (driver's side speedo drive) after '65, but not Corvettes or Camaros - they all used the 584 (pass. side speedo) tailhousing.
