Author Topic: Which Distributor was used on the L30 engine?  (Read 5046 times)
MyRed67
  • SZZLN 67
« on: June 06, 2013, 10:58:47 PM »
  I have found conflicting lists on which Distributor was used on the L30  275 hp. 327.  I have found lists which say #1111124 and others that say #1111249.  I have a #1111249 with Date code 6H22 on the car.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: Which Distributor was used on the L30 engine?
« Reply #1 on: June 06, 2013, 11:34:26 PM »
The 1111249 is correct for a 67 L30
MyRed67
  • SZZLN 67
« Reply #2 on: June 06, 2013, 11:49:39 PM »
Thanks Ed!  That was Quick.
1967 Camaro  LOS  11A
« Reply #3 on: June 07, 2013, 12:08:34 AM »
35 minutes and 39 seconds to be exact!   ;)
MyRed67
  • SZZLN 67
« Reply #4 on: June 07, 2013, 05:41:39 AM »
  While on this subject, how bad is 2 months earlier for this Distributor on a Oct. 26 built Engine?  Would the fact that this is fairly early build figure into equation?
1967 Camaro  LOS  11A
« Reply #5 on: June 07, 2013, 02:51:18 PM »
Quote
The distributor was installed at Flint when they assembled the engine, so it should be fairly close to the engine build date. It's within the normally accepted range, but in my opinion, a little too early.
« Last Edit: June 07, 2013, 07:53:02 PM by Ed Bertrand »
MyRed67
  • SZZLN 67
« Reply #6 on: June 07, 2013, 07:47:50 PM »
OK, that's pretty much what I figured.  Thanks, Ed!
1967 Camaro  LOS  11A
