Author Topic: Lacquer Vs. Enamel for the Camaro  (Read 13572 times)
llskis
« on: June 03, 2013, 01:00:43 PM »
We all know the early Camaro's used lacquer paint and the newer ones use enamel. Does
anybody know what was the year of the changeover? Larry
1969 Z28 Non-Radio and Jeriry MacNeish Certified
Re: Lacquer Vs. Enamel for the Camaro
« Reply #1 on: June 03, 2013, 01:26:15 PM »
In 1977 model year, Chevrolet still used lacquer; by 1981 my, they'd switched to enamels ( I suspect? the Corvette was the last model to change, which happened June of 1981 when Corvette production was moved to Bowling Green from St Louis)....  that's as close as I can narrow it down to...
Mark
« Reply #2 on: June 03, 2013, 05:11:56 PM »
In 78 GM started the transition to water borne paint (which was the death knell for the Framingham Ma plant)  I remember looking at a 78 T/A and it had some of the worst orange peel paint that I had ever seen on a production car.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #3 on: June 03, 2013, 05:17:53 PM »
The Norwood paint shop was modernized and converted from acrylic lacquer to basecoat/clearcoat for the new 1982 3rd-generation car.
« Reply #4 on: June 04, 2013, 02:24:32 AM »
Which by the time I purchased my '85 Z new, had become the nearest next-to-nothing paint film thickness known to man. I traded the car off with 19K miles on it in '87, maintained extemely well, and the paint was already coming off the hood. Film thickness had to be in microns, and very few of them at that. Loved the old underpowered black Z, though - still have the build sheet around here somewhere.
Sorry to digress, but I also liked my '69's lacquer a lot more, especially in LeMans Blue.
festival
« Reply #5 on: June 04, 2013, 02:46:03 AM »
Norwood started out with Turbo Bells and Hi-Solids enamel in 1982 which was modified to BC/CC.    When it came on line in late 1981 it was the best paint system in the industry.  The Norwood Facility was toured by Benz and Toyota and others - because of the paint shop.
Due to environmental restrictions in California- the LOS built cars were stuck with an inferior water based paint shop and system.
HOGDADDY
« Reply #6 on: June 08, 2013, 11:04:47 PM »
FWIW I have a Norwood 1980 Camaro that I bought new and it still sports the original lacquer paint.
festival
« Reply #7 on: June 08, 2013, 11:17:42 PM »
 HogDaddy... You should consider meeting the men who built your car.   We are actively looking for original paint cars for the 2013 Norwood Reunion in July.
« Reply #8 on: June 09, 2013, 12:51:43 AM »
For those of us who don't know about a 'Norwood Reunion', can you elaborate?   My '69 hugger orange/black Z28/RS also has the original 'Fisher' paint, although some parts of the Norwood Assembly Paint (front clip) have been resprayed.
« Reply #10 on: June 09, 2013, 02:48:35 AM »
Wow, I had no idea GM was working with water borne paints in production 35 years ago. We were switching to water borne paint 7 years ago and one of the negatives with its use was orange peel.
festival
« Reply #11 on: June 09, 2013, 10:46:39 PM »
Oh yes.. the EPA was cracking down on the older plants over lacquer and plant emissions.  Orange peel was only one problem- the early WBP technology did not hold up well as a finish either.
« Reply #12 on: June 10, 2013, 12:47:02 AM »
How so? Only the base is waterborne which lays down flat, the clear is still solvent. Waterborne clears are still experimental. Nobody I know who uses waterborne today dislikes it.
