Author Topic: 67 Camaro 327 MN code engine  (Read 4183 times)
sedanman67
« on: May 21, 2013, 01:12:36 AM »
Lookin for the value of engiine.   Is a 67  MN code 327-275 Camaro engine that was donated by GM to a Community College for the students.   Engine was on test stand and was used for electrical problems.   Had 30 Hours run time on the meter.  It has the 4 bbl intake, pulleys, fuel pump, fuel line, exhaust manifolds, water pump, all original to the engine.   Looking for a value as I will be selling it.  Does not have Vin stamp on it.  Was never installed in a Camaro.   Thanks for your help.
sedanman67
Re: 67 Camaro 327 MN code engine
« Reply #1 on: May 21, 2013, 11:33:35 AM »
ttt
« Reply #2 on: May 21, 2013, 02:56:22 PM »
I would think it would be of interest to someone needing an engine like that.   Value would depend much on the need for a rebuild, as just the 'out of pocket' parts and machine work would run over $2K...
sedanman67
« Reply #3 on: May 21, 2013, 04:59:23 PM »
I would not think it would need a rebuild.   Under the valve covers looks like brand new.   30 hours run time on an stand does not equal much wear.   I would install a new rear seal and valve stem seals since they are rubber and maybe dry, this would be the time to do that.
Thanks for the reply
« Reply #4 on: May 22, 2013, 02:48:36 PM »
When was it donated?
Someone doing a 67 would like to have that - just need to find the right person.
