Author Topic: 4053 holley fast idle cam  (Read 7874 times)
wisemanz28
« on: May 16, 2013, 02:21:59 AM »
What is the correct part number for a 4053 holley carburator fast idle cam.
69Z28
  • 69 X33D80 Z28
Re: 4053 holley fast idle cam
« Reply #1 on: May 16, 2013, 05:26:46 AM »
GaryC
« Reply #2 on: May 16, 2013, 06:04:56 AM »
It's the part labelled 29 on the diagram, located HERE. I can't check my Holley parts catalog at the moment, but I'm sure if you called Holley Tech Support, they'd be able to look it up for you.
Everett#2390
  • ^Bess
« Reply #3 on: May 16, 2013, 10:40:24 AM »
Holley P/N 45-376
wisemanz28
« Reply #4 on: May 16, 2013, 08:21:48 PM »
My original carb has a 41r499 fast idle cam on it, but my spare list carb has a 41r539 fast idle cam on it. Which one is correct?
69Z28
  • 69 X33D80 Z28
« Reply #5 on: May 16, 2013, 10:58:35 PM »
I believe it's the 41R-539. Looking at a copy of a 4053 parts breakdown 'Holley Carburetion Variable Specifications And Parts' with part numbers that I have had since 1974 indicates (136)41R-539. Exploded view shows fast idle cam like what Everette's part number shows, but that not what is on a 4053. The one on the ebay auction may be green, but is more like what's on the OEM carbs.
Here is a pic of one.
GaryC
wisemanz28
« Reply #6 on: May 17, 2013, 12:11:30 AM »
That light colored fast idle cam looks just like the one on my original 4053 carb, now where do you find this cam?
69Z28
  • 69 X33D80 Z28
« Reply #7 on: May 17, 2013, 12:38:20 AM »
Did you check out the link I posted? That should be it, if that is what your looking for.
Here is a post on the Corvette site talking about it.
http://forums.corvetteforum.com/c1-and-c2-corvettes/290837-holley-again-fast-idle-cam.html
Something from the Supercar website.
http://www.yenko.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=394461
GaryC
Azure1969Z/28
« Reply #8 on: May 18, 2013, 10:57:29 PM »
419499 is correct if it's green it's incorrect should be white(ish) Call Craig's Carb Restoration 386/518-6040 carbguy@cox.net. he has the #'d part and also the correct choke pull off w/the angled vacuum port.
