Author Topic: Correct alternator belt for 67 350?  (Read 5531 times)
1967RS/SS
« on: May 15, 2013, 03:09:08 AM »
Just put original iron intake and script valve covers on and the alternator belt does not fit.  The alternator hits the valve cover which doesn't allow the belt to slip over the pulleys.  That's with all the brackets loose too.
Engine is L48 350 w/ AIR and PS and no AC
Anyone know the dimensions and/or part number I would need?  AIM shows p/n 3847708 for a V8 and Pep Boys gave me what's in their computer...
« Last Edit: May 15, 2013, 03:27:42 AM by 1967RS/SS »
1967 RS/SS L-48
Van Nuys 01C
Joseph
tom
    • Discount Internet Services
Re: Correct alternator belt for 67 350?
« Reply #1 on: May 15, 2013, 04:23:24 AM »
You can get belts by the inch at most auto parts. If the one you have is too short get some cord wrap around the pulleys. Measure the length of the cord, get a belt that long. Make sure it is the right width. You should be good to go. Measure carefully.
tom
69 X11 Z21 L14 glide
o
1968 Z28
« Reply #2 on: May 15, 2013, 04:56:05 AM »
1969 Camaro Parts book -  #3847708 - 3/8" x 53 1/2"
1975 GM parts book list the number for the same specs as #9433759.  This number may be replaced as of today, but if you give them the specs listed above they can probably crossreference to the right size belt.
« Last Edit: May 15, 2013, 05:13:08 AM by 1968 Z28 »
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
