Author Topic: Correct 69 Z/28 Coil Springs  (Read 35019 times)
69Z28freak
« on: May 12, 2013, 05:29:07 AM »
Here are the coils springs that came out of my car on the left. The ones on the right are the ones I was planning to put in my car. The ones on the right are  small block springs and the ones on the left are the factory 6 cylinder springs. The 6 cylinder springs are longer than the V8 springs. I am wondering which springs to use in  my car. I don't want my car to sit any lower in the front than it was with the 6 cylinder motor. Just curious what the experts know about coil spring rates and ride height etc.
Mike 1969 Grandma Camaro
Re: Correct 69 Z/28 Coil Springs
« Reply #1 on: May 12, 2013, 09:00:26 AM »
Some good reading on spring rates and suggestions on replacement spring part numbers HERE. I put Hotchkis 1907F springs in my car, but the engine and trans are currently out, so I can't confirm what the ride height is, relative to stock. However, they are 2" lower than stock on paper, so probably not what you're looking for.
69Z28freak
« Reply #2 on: May 12, 2013, 09:47:47 AM »
Thanks Tim. Good information.
BillOhio
    • photobucket
« Reply #3 on: May 12, 2013, 04:27:45 PM »
I had a set of small block springs from HBC and the car sat almost as high as it does with the motor out. I looked up david pozzi's site and it has alot of good info with moog part numbers.  If your doing a z, they sat lower than a small block car.
http://www.pozziracing.com/camaro_spring_info.htm
1968 RS 327 4 speed
69Z28freak
« Reply #4 on: May 12, 2013, 08:14:13 PM »
Interesting. I did not know that Z/28's sat lower than other small block cars. I have seen however several restored Z/28's that sat quite high.
« Reply #5 on: May 12, 2013, 09:56:19 PM »
check out UPC 0  Sheet A10 in the '69 AIM.   It has several measures whch shows the height differences.   It's  from minimal to less than an inch, but it is enough to be noticeable eg as compared to a typical SS/V8 camaro.
69Z28freak
« Reply #6 on: May 12, 2013, 10:55:23 PM »
THANKS GARY I will check it out.
« Reply #7 on: May 14, 2013, 04:57:00 PM »
Bob Harris stated that if springs from him were installed(front as well) then the car will sit correctly.
69Z28freak
« Reply #8 on: May 15, 2013, 04:45:49 AM »
Thanks James. I think I have the Bob Harris rear Leafs, at least they appear to be the same visually as his units. The coil springs going in my car are the front coil springs that came out of the 04 C 10/10 RS Z/28, with several other parts as you already know.
69Z28freak
« Reply #9 on: May 16, 2013, 04:24:51 AM »
I like this ride height. Not sure if this is correct, but this is what I hope I am going to get with the coil spring leaf spring combo that I have.
69Z28freak
« Reply #10 on: May 16, 2013, 08:37:57 AM »
These pics also show the stance I like. Assuming these cars were restored to a showroom stance.
ban617
« Reply #11 on: May 21, 2013, 01:10:12 AM »
  looks a lot higher than mine
69Z28freak
« Reply #12 on: May 21, 2013, 01:24:51 AM »
Can you post a picture of yours. I am looking for a restored to original ride height photo, since an original car would be sitting much lower I would assume.
ban617
« Reply #13 on: May 22, 2013, 04:04:10 AM »
 well the car that I have is the one Van/ Chevy Thunder on TC its Daytona Yellow VanNuys car .There are over a hundred pics of it  I don't know how to post pics sorry the thread on tc is 1969 Z/28 dated oct 8 8 scroll down the page and he has a link to the photos ...Many many photos of my car there ..
Kelley W King
« Reply #14 on: May 22, 2013, 12:11:56 PM »
I have a 69 SS big block (52k) and a 69 Z (64k). They are sitting side by side in my shop. The Z is noticeably lower by about an inch.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
