Author Topic: Ball Joints 69 Camaro  (Read 19347 times)
NoYenko
Re: Ball Joints 69 Camaro
« Reply #16 on: May 19, 2013, 05:49:11 PM »
I am pretty sure those Tie rod ends on E bay are not correctly listed. I believe the grease fitting should be parallel with the stud on both inner & outer tie rod ends.George
lynnbilodeau
« Reply #17 on: May 19, 2013, 08:40:43 PM »
George.  You are correct.  I didn't even look because I am not interested in them at that price anyway.  Those must be later service replacement parts, consolidated with Vega Monza, etc.
69Z28freak
« Reply #18 on: May 21, 2013, 07:38:05 PM »
Here are the 2 type of ball joints available from Heartbeat City.
There are the factory assembly line correct units that are made offshore but look correct.
These units are the made in USA, however, they do not appear as correct. Which ones are guys using for restorations is the question.
Mike 1969 Grandma Camaro
