This is the reply I just recv'd about the carb, no pic was supplied when I asked. Actually I tested the reserve ($500.00), yeah risky I know, and it hasn't been met yet. Not sure if I should trust it.
This is it's original 4053 Base plate. It has 3 vacuum sources, an angled 1/8" port directly under the primary float bowl which was used for the choke pull-off and/or smog system vacuum source, a 3/16" vacuum port on the right front corner for the vacuum advance, and a stepped 3/8" port on the right rear corner for the PCV hose. The Fast Idle Lever is missing, the Factory Screw is intact. Found one here on ebay for 10 bucks.
- wikiwikirulz
