Author Topic: Trunk specifics  (Read 5968 times)
Rufcar
Trunk specifics
« on: April 12, 2013, 05:02:55 PM »
In a 69 trunk, where the floor meets in inner quarter panel there is a appox 1/2" gap was that always like that or does seam filler go there before spraying the trunk floor?
lynnbilodeau
Re: Trunk specifics
« Reply #1 on: April 12, 2013, 06:11:51 PM »
It is open.
That is one reason so many quarters rust.  Debris gets down there and collects moisure.
When I replaced my drop off on the drivers side I found:
3 drill bits
2 pieces of sandpaper
assorted wood and sheet metal screws
unidentifiable papers
muck and dirt (just enough to hold moisture.
GM probably should have put a big flap down there to allow exit, similar to what is on the back inside edge of the rockers.  Instead, there is a little tiny slit under the body plug.
lynnbilodeau
Re: Trunk specifics
« Reply #2 on: April 13, 2013, 05:07:44 AM »
Boy my spelling sucks.
Rufcar
Re: Trunk specifics
« Reply #3 on: April 13, 2013, 08:15:07 PM »
Because im using my cell phone my spelling not awhole lot better ! tkx for the info. Jim
Rufcar
Re: Trunk specifics
« Reply #4 on: April 17, 2013, 03:18:39 AM »
did anyone here fill in that gap between the trunk floor and the inside quarter panel ?
jims69
Re: Trunk specifics
« Reply #5 on: April 23, 2013, 07:45:43 AM »
No,  I'm more of an authentic type of guy than a customizer.   We carry a plastic tote box in the trunk for small items and keep it in the middle of the trunk, in the area that is lower than the side panels.   In this way we keep things from rolling around or falling down the side gaps.
