Author Topic: 69 Camaro power steering  (Read 7515 times)
waynechipman
« on: November 07, 2005, 04:37:53 PM »
I have a 69 Camaro it has the original power steering box. I have three different mounting brackets for the power steering pump. Were there any differences between small block brackets for the pump. And is there anywhere I can get an exploded picture of the bracket setup for the pump. Help on this one would be greatly appreciated. Thanks Guys
Re: 69 Camaro power steering
« Reply #1 on: November 08, 2005, 03:25:49 PM »
All small-block power steering setups used the same brackets - shown in detail in Section N40 in the Assembly Manual.  :)
waynechipman
« Reply #2 on: November 08, 2005, 07:25:14 PM »
Thank You
67RSSS
« Reply #3 on: December 19, 2006, 10:04:00 PM »
Is it normal for the pump bracket to flex a little? Ive been getting a little belt squeel but then noticed that the whole pump flexes some.  I took it apart to check for cracks, and none found.  Any ideas??
cib12
« Reply #4 on: December 31, 2006, 08:58:17 PM »
from my old garage tech memory- most GM products had a rear bracket on the rear of the ps pump--this bracket then was bolted on to one of the motor mount bolts( a bolt that holds the mount to the block.  with out this bracket the pump was not stable-I fixed a lot of these in the 70s & 80s  when the motor we put in under trees.
