Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
69 Camaro power steering
« previous
next »
Print
Pages: [
1
Author
Topic: 69 Camaro power steering (Read 7511 times)
waynechipman
Member
on:
November 07, 2005, 04:37:53 PM »
I have a 69 Camaro it has the original power steering box. I have three different mounting brackets for the power steering pump. Were there any differences between small block brackets for the pump. And is there anywhere I can get an exploded picture of the bracket setup for the pump. Help on this one would be greatly appreciated. Thanks Guys
Tweet
Logged
CRG Member
Re: 69 Camaro power steering
Reply #1 on:
November 08, 2005, 03:25:49 PM »
All small-block power steering setups used the same brackets - shown in detail in Section N40 in the Assembly Manual.
Logged
waynechipman
Member
Reply #2 on:
November 08, 2005, 07:25:14 PM »
Thank You
Logged
67RSSS
Newbie
Reply #3 on:
December 19, 2006, 10:04:00 PM »
Is it normal for the pump bracket to flex a little? Ive been getting a little belt squeel but then noticed that the whole pump flexes some. I took it apart to check for cracks, and none found. Any ideas??
Logged
cib12
Member
Reply #4 on:
December 31, 2006, 08:58:17 PM »
from my old garage tech memory- most GM products had a rear bracket on the rear of the ps pump--this bracket then was bolted on to one of the motor mount bolts( a bolt that holds the mount to the block. with out this bracket the pump was not stable-I fixed a lot of these in the 70s & 80s when the motor we put in under trees.
Logged
Print
Pages: [
1
« previous
next »
General Discussion
