Author Topic: 67-68 Z28 Crank Pulley pn 3858533 BJ ?  (Read 18108 times)
Re: 67-68 Z28 Crank Pulley pn 3858533 BJ ?
« Reply #15 on: February 15, 2013, 03:51:12 PM »
Generally, the pulleys aren't balanced as part of the rotating assembly.  I've had several engines balanced over the years, and never did the shop allow me to include the pulleys.. :)   .   They balance the internals, and then balance the damper and flywheel.
« Reply #16 on: February 16, 2013, 05:50:30 AM »
Here are a couple of photos I took. Maybe not the greatest but at least the parting line on the top between the two fan belt grooves is pretty apparent. These are two pics from two pulleys I have and not two shots of the same pulley.
« Reply #17 on: February 16, 2013, 06:46:10 AM »
So do I have only the 'front' pulley, Jon? Can you take a pix also of the front and the back?
« Reply #18 on: February 16, 2013, 07:48:47 AM »
Gary, to me it seems like you only have the back part of the pulley (the rear groove).
« Reply #19 on: February 19, 2013, 06:02:56 PM »
Yes, that's the way it appears, given the stamped number on the front...   I've also got a couple of questions concerning the difference in damper between the '67 and '69 302, but I'll start a new thread for that.   Since you have a '67 Z28, Jon..  I Hope you can help me out again!  :)
