Author Topic: 69 smallblock (302) Oil dip sticks  (Read 37349 times)
jdv69z
  • 69 RS Z/28 52E
Re: 69 smallblock (302) Oil dip sticks
« Reply #30 on: February 20, 2013, 03:24:43 PM »
Question: My green tip dipstick does not have the "Use GM...." stamped on it anywhere. Just the add/fill markings. Does that mean anything?
Jimmy V.
69Z28
  • 69 X33D80 Z28
« Reply #31 on: April 05, 2013, 06:47:41 PM »
First week 06A
Member            Production            Dipstick
                    Plant       Week           Type
jdv69z            NOR        10(68)        flat
firstgenaddict   NOR       10D (68)     flat
LatebuildZ         ??         Nov(68 )     green tip
68CamaroZ28  NOR       11 (68)        green tip
Boston14        NOR        11D (68)     flat
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
X77-69Z28      NOR        05A             flat
RSZMJT          NOR        06A             flat
69Z28            NOR        06A            flat
BULLITT65      NOR        08C             flat
69Z28-RS        NOR        09C             flat
LatebuildZ       NOR        10C             flat
GaryC
« Reply #32 on: December 12, 2020, 06:06:26 AM »
Added my early LA car:
                    Plant       Week           Type
BULLITT65.       LA.        10B (68)     flat
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
69Z28            NOR        06A            flat
« Reply #33 on: December 12, 2020, 08:28:38 PM »
I have had probably more than my share of experience with dipsticks.  :)
Red, yellow, gray, brown, etc.  Red one shown is a newer reproduction. Others are original.
john jay 69Z
« Reply #34 on: December 13, 2020, 07:54:14 PM »
Hi All,  its my first time engaging in conversation. I have a green tip dipstick on my  late Sept 69 302
 but mine has 3951576 after -  USE SE ENGINE Oil is mine original
Really enjoy the club
regards
John
« Reply #35 on: December 14, 2020, 03:57:59 AM »
regards
John
Welcome to the CRG, John - Norwood or Van Nuys (LA) production ?
« Reply #36 on: December 14, 2020, 07:50:28 AM »
Mine has the flat tip dipstick, but haven't included that as a data point as it was in a CE-block engine. May or may not be original, depends on what was swapped over.
john jay 69Z
« Reply #37 on: December 14, 2020, 09:55:58 AM »
Thank you Steve,
my car is a Norwood built 3rd week of September
Hans L
« Reply #38 on: December 31, 2020, 02:23:25 AM »
My Z, under Hans L is VN built.  04B.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
« Reply #39 on: December 31, 2020, 11:35:47 PM »
The yellow tip is a later service replacement is it not?
John Jay, I believe our great contributor JohnZ had stated what’s on your stick is a later service replacement but lots of questions on some dipsticks.
BillG
« Reply #40 on: January 02, 2021, 12:42:48 AM »
Mabey off topic but, are the metal paint/finishes different on the flat vs colored tipped? Looks like some green tipped stick metal finishes were black?
Bill Garrett
« Reply #41 on: January 02, 2021, 02:52:55 AM »
Yellow is 68 and 69 big block. 70 too I think.  Light red/salmon is 67 big block. The red reproductions are too “red” and should be somewhere between red and pink. I will see if I can find an original and post if I find one. The green tips I have are from original 69 to 72 engines.
« Last Edit: January 02, 2021, 05:52:59 AM by bcmiller »
« Reply #42 on: January 02, 2021, 03:38:23 AM »
Does anyone know what a flat white tip big block would have been for?
« Reply #43 on: January 02, 2021, 03:49:09 AM »
Let me do some checking. I have all the colors written down somewhere. From memory, white dipstick was for 6 cylinder engines mid to late 60s.
« Last Edit: January 02, 2021, 05:06:59 AM by bcmiller »
« Reply #44 on: January 03, 2021, 01:42:53 AM »
Sorry, my comment on your pictured yellow dipstick refers to that one being a later service replacement due to the deep dimple piercing noted on later service replacements.
