Author Topic: 69 smallblock (302) Oil dip sticks  (Read 37346 times)
jdv69z
  • 69 RS Z/28 52E
Re: 69 smallblock (302) Oil dip sticks
« Reply #15 on: February 03, 2013, 10:09:48 PM »
jdv69z              ?           10(68)?      flat
Norwod  10/68
Jimmy V.
« Reply #16 on: February 03, 2013, 11:52:30 PM »
Each new poster should copy this and add his information to the list before posting.
type 1)   flattened handle on end, no PN, no plastic tip, stamped "ADD |           | FULL   USE GM 6041-M QUALITY MS OIL   E".  (E turned 90 deg).
type 2)   light green tip on handle, no PN, no dimple,  stamped    "ADD !           ! FULL   USE GM 6041-M QUALITY MS OIL   M".
Member            Production           Dipstick
                     Plant       Week        Type
69Z28-RS        NOR        09C            flat
JOHNZ            NOR        02D            flat
BULLITT65      NOR        08C            flat
RSZMJT          NOR        06A            flat
jdv69z            NOR        10(68)        flat
(add yours here)
« Reply #17 on: February 05, 2013, 02:02:18 AM »
This is the green tipped stick out of the Nov68 built DZ motor. Having the GM 6041 M is the key I believe as judges seem to key on that.
Writing on the stick is the same as what's on the pic supplied by JohnZ.
x77-69z28
« Reply #18 on: February 05, 2013, 04:45:45 AM »
My 05A Z has the flattened type.
« Reply #19 on: February 05, 2013, 12:41:50 PM »
type 2)    green tip on handle, no PN, no dimple,  stamped    "ADD !           ! FULL   USE GM 6041-M QUALITY MS OIL   M".
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
68CamaroZ28    ?          11(68)        Green tip
X77-69Z28      NOR        05A            flat
« Reply #20 on: February 05, 2013, 02:36:38 PM »
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
68CamaroZ28  NOR        11(68)        Green tip
« Reply #21 on: February 07, 2013, 01:43:36 AM »
firstgenaddict - NOR - 10D (68) - Flat
« Reply #22 on: February 07, 2013, 02:16:41 AM »
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
z28z11           NOR         01C            flat
latebuildZ
« Reply #23 on: February 07, 2013, 03:53:20 AM »
Latebuildz   NOR       10C       flat
Hans L
« Reply #24 on: February 12, 2013, 04:04:36 AM »
My 04B '69 Z has the same style as John Z.   Flat tip, same text, 90 deg "E".
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Boston14
« Reply #25 on: February 17, 2013, 12:30:46 AM »
My 11D(68) Norwood  1969 RS/SS 350 Convert has the same stick that John Z has (flat).
boston14
1969 SS/RS 350 Convertible
« Reply #26 on: February 17, 2013, 04:17:55 AM »
(trying to bring the list up to date)...
                     Plant       Week        Type
JOHNZ            NOR        02D            flat
RSZMJT          NOR        06A            flat
z28z11           NOR         01C            flat
Boston14        NOR         11D (68)     flat
Hans L                           04B            flat
LatebuildZ                     Nov68        green tip
LatebuildZ       NOR        10C           flat
firstgenaddict   NOR        10D (68)    flat
« Reply #27 on: February 19, 2013, 05:26:00 AM »
Just a suggestion - it's easier to see trends if the data is organized by build date.
Also, this research is applicable to any 69 SB.
« Reply #28 on: February 19, 2013, 02:30:35 PM »
Re: 69 smallblock V8 (302, 307, 350) Oil dip sticks  (reorganizing per Kurt's suggestion)
type 1)   Flattened handle on end, no PN, no plastic tip, stamped "ADD |         | FULL   USE GM 6041-M QUALITY MS OIL   E ".  (E turned 90 deg).
type 2)   Green tip on handle, no PN, no dimple,  stamped             "ADD |         | FULL   USE GM 6041-M QUALITY MS OIL   M ".
                    Plant       Week           Type
LatebuildZ         ??         Nov(68 )     green tip
68CamaroZ28  NOR       11 (68)        green tip
z28z11           NOR         01C            flat
JOHNZ            NOR        02D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
Where are the LA cars??
Each new poster should copy this and add his information appropriately to the list before posting.
« Reply #29 on: February 19, 2013, 03:02:27 PM »
Added one -
                    Plant       Week           Type
z28z11 (X77)   NOR         01C            flat
JOHNZ            NOR        02D            flat
z28z11 (Z11)   NOR        03D            flat
Hans L              ??         04B             flat
RSZMJT          NOR        06A             flat
