Author Topic: Earliest 3969341 and Latest 3894860 axles  (Read 236627 times)
Re: Earliest 3969341 and Latest 3894860 axles
« Reply #195 on: April 06, 2023, 01:37:58 AM »
Build date 06A X66 396
Casting number 860NF
Assembly stamp BU 1126 G1 E
Casting date K228
Casting and assembly date look fine and thanks for submitting. Is that the original axle for your car? If so, we may want to document it more. That is a fairly large spread from axle assembly to your car assembly but it is possible. Would you happen to have the Protect-o-Plate for your car?
The thread is mostly concerned with the time frame of axles cast or assembled from about May of 69 through the end of the model year.
boomer632
« Reply #196 on: April 06, 2023, 11:24:01 AM »
The CHP report for the car states that he has seen late build examples with rear axle stamps with 5 months spread, and could not say for certain the axle is original to car but was possible. He did certify that the axle stamps are legitimate and not re-stamps and the car was born with 12 bolt. I do not have the POP for the car.
06A X66 711 57 57 L78 M22 BU
« Reply #197 on: April 06, 2023, 02:17:54 PM »
That’s a 7 month spread. Possible. Just wondered if there was solid proof, because it’s a potential area to learn.
boomer632
« Reply #198 on: April 06, 2023, 02:54:16 PM »
Yea I know its a stretch but I offered it as a possible data point.
« Reply #199 on: April 06, 2023, 04:10:02 PM »
It's not original. Axles were very tight in early 69. There is one 06A car in the database with an axle that is in March (and not a common axle code). All the rest are May / June axles.
« Reply #200 on: April 06, 2023, 04:29:18 PM »
I am still EXPLORING the thinking
"trying to clear out parts toward the end of the model year, because the system was not a first in / first out setup."
Not saying that is the case....
boomer632
« Reply #201 on: April 06, 2023, 06:22:19 PM »
As I said Im just going by what JM stated in report.. only offering data
« Reply #202 on: February 21, 2024, 04:59:30 PM »
Not a 12 bolt, but a late 69 model year 10 bolt using the 3 letter code convention.
Badshifter
« Reply #203 on: February 22, 2024, 02:21:57 AM »
My 09C has H59 casting date and C BU 0814G1 stamp.
Fixed!
« Last Edit: March 01, 2024, 08:44:34 PM by bcmiller »
1969 Z28 X77 09C
« Reply #204 on: February 27, 2024, 12:55:39 AM »
Thanks! I will add it to the list.
« Reply #205 on: March 01, 2024, 05:53:47 PM »
Updated March 1, 2024
Please when submitting data - put all of the information requested in ONE POST - PLEASE.
Some notations have been made for C BU axles where the C has been peened. I did not note this on all of the ones listed.
Here is what we have so far.  We need more data points for axle assembly dates between early June and early August.  My apologies if your data was inadvertently missed.
It appears that the 341 casting number started being used in June. It appears that the 3 letter code had started by early August, possibly earlier.
Remember that there was a shutdown for the latter part of July and into very early August.
01C
BM 0124G1
860, casting date A 21 9
06A - 9N665238
BM 0625G
860, casting date unknown
07A - 9N6687XX
BU 0630G2
860, casting date E 26 9
Unknown build date
BE 0708G1
860, casting date D 28 9
Unknown build date possible over the counter/warranty axle
C 107 231 G1 with 7 and 1 peened out, shows C 10 23 G1
341-A, Casting date E 14 9
08E  9N677954
C BS 0805G
341, casting date G 25 9
08C
C BL 0806G1
341, casting date G 23 9
Unknown build week and/or VIN
C BM 0807G1
860, casting date F 24 9
Unknown
No assembly stamp, possible warranty axle
341, casting date F 28 9
08D  9N6745xx
C BU 0818G2
unknown casting number or date
08D
C BS 0820G2
341, casting date H 11 9
08E, 9N677163
C BL 0812G2
341, casting date H 5 9
08E
C BU 0828G2
341, casting date H 13 9
08E
C BU 0828G2
341, unknown casting date
09C
C BU 0814
341, casting date is H 5 9
09A - 9N680789
C BU 0828
09A
C BU 0826 or 0828
09C
C BU 0829G1
341, casting date G 31 9
C BS 0829G1
341, casting date H 17 9
09C 9N684457
C BU 0829G1
341, unknown
Unknown build date or VIN possibly from a Nova
C BS 0909G1
09C   9N685397
C BU 0910G1
341, casting date I 2 9
C BU 0916        C area is peened
341, casting date I 6 9
C BU 0922G2    C area is peened
341, casting date I 11 9
10A
C BU 0929G1    C area is peened.
341,
Unknown build date or week
C BS 1022G1
341 casting
C BS 1028G1
341, casting date J 3 9
C BE 1030G1 not peened
341, casting date J 3 9 or J 8 9 (hard to read)
« Last Edit: March 04, 2024, 08:52:19 PM by bcmiller »
Badshifter
« Reply #206 on: March 01, 2024, 08:25:26 PM »
My 09C has H05 casting date and C BU 0814G1 stamp.
So Sorry! Casting is H59!
1969 Z28 X77 09C
« Reply #207 on: March 01, 2024, 11:09:48 PM »
Another 10 bolt
