Author Topic: Earliest 3969341 and Latest 3894860 axles  (Read 323669 times)
« on: January 09, 2013, 03:48:08 AM »
It appears that 12 bolt rear axles with casting number 3969341 started showing up in 69 Camaros sometime around early August of 1969.  Prior to this, only the 3894860 casting number was used.
What I am looking for are dates (casting date of housing and assembly date stamp - with letter codes - on the axle tube) for early 3969341 axles and late 3894860 axles.  If you know it is original to the car, you can post the body assembly date from the cowl tag too.
Please let me know what you have.  Post pics if possible.  There was probably somewhat of an overlap, but not sure how much.
Thanks in advance!
Bryon
x77-69z28
Re: Earliest 3969341 and Latest 3894860 axles
« Reply #1 on: January 12, 2013, 07:30:37 AM »
Where are the casting numbers?
« Reply #2 on: January 12, 2013, 05:08:22 PM »
Here you go.
« Reply #3 on: January 12, 2013, 11:33:47 PM »
09A Dusk Blue Z28 124379N680789
12-bolt 3:73 Posi:
assembly stamp C BU 0828
                           E
Casting # 3969341
« Reply #4 on: January 14, 2013, 02:06:11 AM »
I parted out 9N677954  CBS0805G  341, cast G259. I only know of 2 341's before that one. There have to be more.....
Not a lot of axle casting data on these late cars in the db.
« Reply #5 on: January 14, 2013, 05:22:18 AM »
My 09C Z28/RS has the 3969341 rear, stamped BU0828
Gary
x77-69z28
« Reply #6 on: January 14, 2013, 07:09:30 AM »
Here you go.
Oh. Thought he was talking about the axles themselves! Duh!!!
69glacierblue
« Reply #7 on: January 19, 2013, 04:11:27 AM »
Maybe a little earlier than you want, but here goes:
06A
9N665238
BM0625G
Cast 860
Dennis
Dennis
'69 SS350 Vert (X55) 4-sp.
'10 2SSRS RJT M6
« Reply #8 on: February 09, 2013, 06:33:47 AM »
Keep the information flowing guys. Thanks for the replies so far!
restore-z28
« Reply #9 on: February 10, 2013, 08:20:45 PM »
Build date 08E (Z28)
Casting number 3969341
Assembly stamp CBU 0828 G2
Casting date H139
Sonny
1969 Z28 Camaro, sold :-(
1970 Z28 Camaro
www.camaros.ca
« Reply #10 on: February 12, 2013, 11:19:45 PM »
Gary
Gary, is it stamped BU or CBU?  The one Kurt posted had a casting date earlier than yours and it used the 3 letter code.
I am just trying to see if maybe the casting date change corresponded with the change from 2 letter codes to 3 letter codes.
« Reply #11 on: February 12, 2013, 11:20:42 PM »
Casting date H139
Thanks!
« Reply #12 on: February 13, 2013, 04:48:37 AM »
Gary
only 'BU'...  2 letter code..   (see photo attached)
and actually I see that I posted the incorrect date...   BU0829G1 ....
« Reply #13 on: February 15, 2013, 06:06:05 AM »
That looks like a C to the left of the BU. Pretty hard to see...
« Reply #14 on: February 15, 2013, 01:46:37 PM »
..  then you have better eyes or a better imagination than I, Kurt..  :)
Do you have a photo of a CBU stamp?  I don't think I've ever seen one, so maybe it's not like I was expecting..?
or maybe Bryon can post a pix of his as he has a C BU code??
