Author Topic: 4 Spd Shifter Advise  (Read 7012 times)
pracing
« on: December 20, 2012, 06:14:36 AM »
Hi i need a little help making up my mind on my 4 spd shifter for my
67 RS/SS the shifter is getting worn out should i replace it or try & rebuilt it
x77-69z28
Re: 4 Spd Shifter Advise
« Reply #1 on: December 20, 2012, 06:29:02 AM »
Depends on what your plans are for the car. The orig Muncie shifter sucks if you are gonna go racing. It is mounted to the crossmember. A hurst shifter would mount to the tail shaft and move with the transmission under torque. If the car is all original, you don't have a choice.
1968 Z28
« Reply #2 on: December 20, 2012, 05:59:19 PM »
If you choose to go the Muncie shifter route you have two choices, a repo shifter that has all new parts but technically is not an original shifter, or a used one that might not be any better than your old one.  If originality is of no concern to you, the Hurst Competetion Plus is the way to go.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
RAfbody
« Reply #3 on: December 20, 2012, 06:59:08 PM »
Install a hurst competition plus shifter body and attach the Muncie stick.   Would look original in the car and shift better.
Russ
pracing
« Reply #4 on: January 04, 2013, 05:17:50 AM »
I would like to stay with the factory shifter does any one sell a rebuild kit for that shifter ?
« Reply #5 on: January 04, 2013, 06:29:09 AM »
clean and lubricate the mechanism; install new bushings on the rod ends; and perhaps install the GM 'engine torque restraint' to minimize engine rotation during acceleration.
I did a quick search and found this reference:
"Volunteer Vette sells an excellent rebuild kit for the stock Muncie shifter - 'someone' wrote a photo-illustrated technical article on that rebuild in the January '08 issue of "Corvette Enthusiast" magazine."
rsr
« Reply #6 on: January 04, 2013, 12:06:54 PM »
Here's a guy in NC that rebuilds shifters with 45 years experience..336-621-4327 Danny
JoeC
« Reply #7 on: January 12, 2013, 02:57:18 PM »
I have rebuilt a bunch of Muncie shifters and they work pretty good if done right but they were just not designed for hard shifting.
If you like banging gears you want a Hurst
If you want a correct resto you want an original restored Muncie shifter
They are hard to find with all the correct small parts but they are still out there.
