Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
67 350 metal vacum line correct
« previous
next »
Print
Pages: [
1
Author
Topic: 67 350 metal vacum line correct (Read 3975 times)
pracing
Newbie
on:
December 19, 2012, 07:32:07 AM »
Going back to the organal carb on my 67 RS/SS 350/295 Hp & looking for the correct vacum line routing from dist to carb. It had a holley carb & it not sure if the metal line is correct
Tweet
Logged
Hero Member
Re: 67 350 metal vacum line correct
Reply #1 on:
December 19, 2012, 02:54:39 PM »
The 67 L48 engine (350/295) used a Rochester Q-Jet, so you need to get
THIS ONE
Logged
Hero Member
Reply #2 on:
December 21, 2012, 12:32:19 AM »
Hey pracing -
I've got one of these if you need an original - be glad to send it to you if you'll pay the freight. I'll try to dig it out of the frozen garage tonight and get a pic if you want -
Logged
1969 Z11 L48/M35/C60/C06 1949 3100 5wd 235/6
Hero Member
Reply #3 on:
December 21, 2012, 12:54:26 AM »
Maybe its correct for the q-jet but for our Holley set up the kits have the wrong small piece to the carb. Our orig. vs. a piece of the stripped vac. hose.
Our original
Original to left vs. kits piece.
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
Hero Member
Reply #4 on:
December 21, 2012, 04:09:14 PM »
I've been told that the
DOC REBUILD
vacuum hoses are "correct". I haven't checked it out myself, but the same hose was used throughout GM for a number of years, not just Corvette and Camaro.
By the way, there are a couple of good pictures of the Q-Jet tube and hoses in
THIS
thread. This engine is a 68 L30 (327/275) but the setup is the same as the 67 L48 engine (350/295).
Logged
Print
Pages: [
1
« previous
next »
Originality
