Author Topic: cruise control diagram 68 camaro  (Read 27419 times)
rippin
Re: cruise control diagram 68 camaro
« Reply #30 on: January 15, 2015, 03:45:34 PM »
Possibly someone out there has the part number for a 68 camaro regulator ?
« Reply #31 on: January 15, 2015, 04:05:49 PM »
Per the 1968 AIM, UPC K30, sheet A2, the Regulator PN is (or was at time of design):    6465116
big iron
« Reply #32 on: January 15, 2015, 05:48:47 PM »
Same as 67 and bracket is 3927351.
Bob
big iron
« Reply #33 on: January 15, 2015, 06:00:33 PM »
I would bet that the regulator off any GM car would work.
If both speedometer outlets are pointing towards the firewall no. The original has one of the outlets pointing down at right angle.
Bob
rippin
« Reply #34 on: January 15, 2015, 11:13:54 PM »
Thanks guys I will be looking at one next week possibly a friend of mine  in Holland mich thinks he may have one but not sure if it chevelle or camaro   . This dude has two pull barns full lol yep he's a horder
bc69
« Reply #35 on: January 16, 2015, 03:15:57 AM »
Anybody have a pic of diaphragm assy?
Brad
RSSS
rippin
« Reply #36 on: January 16, 2015, 03:34:54 AM »
I'm figuring all this out myself but we're is the diaphragm assembly located on the car. ?
Above is a pic of the area were my swicth button was placed since  1974 for sure as much as I know ,its not on turn Sig but below dash next to power convertible swicth ,any out there have this curse control together with the tilt wheel ?? Would the tilt be a problem with the wire runing though it  and poss developing a break ??       I am looking for the regulator to complete this set up if any one out there knows of one
bc69
« Reply #37 on: January 16, 2015, 03:38:19 AM »
Vaccuum diaphragm under hood. Has 2 vac lines and chain to throttle lever clip
Brad
RSSS
rippin
« Reply #38 on: January 17, 2015, 01:54:23 AM »
The servo right? I have a pic on 2nd page of this post,  Diagrams must be inside unit.          Ok I have two more pics .of the wires ,main vac line,  placement  of the servo three bolt attachment area n opening though fire wall we're all passes though ,        now after unravelling tape around wires I noticed wires looped in harness with only two that would end up hooking to regulator  ,   I wounder if some one had tried to hook the cruise up after it came from GM would they have used so much wire and loop it in the harness ??
bc69
« Reply #39 on: January 17, 2015, 02:11:13 AM »
Having trouble posting pics. What I'm talking about is the part that is behind booster and pulls the throttle open with chain/ Vaccuum. It looks like a mini booster. It has two Vaccuum connections both on same side and a linkage via chain to the throttle. Pm me email and I'll send you some pics of my servo and misc parts. My 67 has a orig cruise on it.
Brad
Brad
RSSS
