Author Topic: LUCAS Hot Rod & Classic Motor Oil  (Read 7764 times)
MyRed67
  • SZZLN 67
« on: December 01, 2012, 07:50:50 AM »
  I think this is relatively new stuff, has anybody here tried it?
http://www.summitracing.com/search/department/oils-fluids-sealer/part-type/motor-oil/brand/lucas-oil/product-line/lucas-hot-rod-and-classic-car-motor-oil
   And what is general concensus here, is it better to change oil before putting the car in storage for Winter, or in Spring when I take it out?
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: LUCAS Hot Rod & Classic Motor Oil
« Reply #1 on: December 01, 2012, 03:52:46 PM »
Unless you have a radical valvetrain, there's no reason to use "boutique" oils.
Change oil just before you put the car up for winter storage - you want fresh, clean oil sitting in it all winter, not last season's dirty oil.
lakeholme
  • 68-12D L30/M35
« Reply #2 on: December 01, 2012, 04:36:11 PM »
X2 to both things John said...
The old oil has all those "nasty deposits" in it, so you would not want it to sit all winter. Even if you haven't driven it that much, you really don't want old oil to sit idle that long.
On all my classic cars, I have an oil change and lube done before I store them. Also, I fill the gas tank and add Sta-bil to keep the moisture down in the tank.  And... I keep an eye on humidity and minimum temperature.
« Reply #3 on: December 01, 2012, 11:10:45 PM »
What's this about winter storage?????     you guys don't drive your cars year around???
*smiling down here in the sunny south*....
PS.  Engines run lots stronger in the winter time when the air gets down in the 30's...  :)
