Author Topic: month code of F muncie?  (Read 7918 times)
BillOhio
    • photobucket
« on: November 26, 2012, 04:35:55 PM »
Anyone ever see f used for a june 69 muncie?
1968 RS 327 4 speed
BillOhio
    • photobucket
Re: month code of F muncie?
« Reply #1 on: November 28, 2012, 05:36:57 PM »
This is the date in question. pretty sure we know its not right but wanted to make sure no one else has seen one
1968 RS 327 4 speed
« Reply #2 on: November 29, 2012, 02:18:29 AM »
The photo isn't good.   Can you provide a better, wider FOV shot?
BillOhio
    • photobucket
« Reply #3 on: November 29, 2012, 03:24:11 AM »
I don't own the car so trying not to show the vin but did make it wider
1968 RS 327 4 speed
« Reply #4 on: November 30, 2012, 01:26:12 AM »
No question in my mind it's a restamp.....
« Reply #5 on: November 30, 2012, 05:46:56 AM »
I have never understood why it's stated that 'F' and 'G' were skipped in the month codes (during 1969?) or all years?  WHY would they do this?      ie. P9H30A is from what date?
BillOhio
    • photobucket
« Reply #6 on: November 30, 2012, 01:15:10 PM »
This should be an H.
Kurt, would an over the counter transmission not have any stamps and that's where this started or did something get covered up to do this
1968 RS 327 4 speed
tmodel66
« Reply #7 on: November 30, 2012, 01:34:35 PM »
June 30th of '69 M 20
Steve Shauger
    • Vintage Certification
« Reply #8 on: November 30, 2012, 03:51:31 PM »
I've seen restamps done on replacemment cases(they were never stamped), some plants stamped the trans on top by the ears so the side is still unstamped and the tops are ground down. Also remember aluminum is very soft and easy to work with so some cases are ground down and refinished with sand casting type finish and restamped.  I would look at the whole trans to see what method was used. A big oops on the use of the F code. Unfortunately this is all too common.
Steve Shauger
« Reply #9 on: November 30, 2012, 09:52:46 PM »
Steve,
So you can you shed any light on WHY '69 Muncies didn't get the F or G codes?
....    and instead they skipped those letters for some reason?   I've heard they did that, but never have heard a reason....
Was this true for ALL Muncies in general, regardless of year?  or only for '69?
« Reply #10 on: November 30, 2012, 10:38:47 PM »
This coding was used for all GM trans (except TH400's) for a number of years. No idea why. There are other oblique date code formats out there.
http://www.camaros.org/drivetrain.shtml#trans
« Reply #11 on: December 01, 2012, 06:55:04 AM »
Crazy stuff for sure....  coding guy must have been stoned..  :)
