Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
10 bolt rearend
« previous
next »
Print
Pages: [
1
Author
Topic: 10 bolt rearend (Read 4855 times)
clean68rs
Member
10 bolt rearend
on:
November 25, 2012, 02:52:41 AM »
I have a 10 bolt rear end in my 68 rs and would like to know more about it. Is it 8.2 or 8.5 Here are numbers I took from it. Drive shaft side. con1 is on the left side fasing it from the front. these numbers are on the right side 889485nf. I would like to put in a locker and want to know weather its a 8.2 or a 8.5 I believe that it is the origanal rear end any help would be appreciated.
Tweet
Logged
Hero Member
Re: 10 bolt rearend
Reply #1 on:
November 25, 2012, 04:13:34 AM »
You're missing a number. It should be 3894859 which is a 1967-1969 Camaro 10 bolt or a (late) 1965-1971 Nova 10 bolt, both being 8.2". Check the date on the other side to narrow it down, and also check the passenger side axle tube to see what ratio it originally came with.
Logged
clean68rs
Member
Re: 10 bolt rearend
Reply #2 on:
November 25, 2012, 12:49:22 PM »
Thank you. Here are some more numbers from the rear face. On left is L157 on right is con 1. Do you know if these rears are all 28 spline ? I know I can open it up to find out but if I dont have to I would rather not Thanks for this info.
Logged
Hero Member
Re: 10 bolt rearend
Reply #3 on:
November 25, 2012, 05:47:01 PM »
L157 is the casting date (December 15th, 1967), and yes, it's a 28 spline. If your car was assembled in late December, 1967 or early January, 1968, it's probably the original axle.
Logged
clean68rs
Member
Re: 10 bolt rearend
Reply #4 on:
November 26, 2012, 02:28:43 AM »
Thank you Ed for that information. Scott
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
10 bolt rearend
