Author Topic: Trunk sound deadner  (Read 69484 times)
67CruiseMaster
Re: Trunk sound deadner
« Reply #60 on: February 28, 2021, 03:09:48 AM »
Does anyone know if it was also used for convertible deluxe interior cars too?
67 Tuxedo Black Convertible.
x66 714
« Reply #61 on: February 28, 2021, 03:20:48 AM »
Read reply #8. Since all deluxe interior cars had a mat, that should be there...Joe
Edgemontvillage
« Reply #62 on: February 28, 2021, 03:32:34 PM »
In post #59 I referred to material that's produced by Repops and is available in kits and as roll goods for the same application. Its the asphalt layer only so a paper top layer would need to be added (a watershield grade material). As mentioned in the post its thin, rigid material that profiles much like roofing with a granular top layer. Here are a couple of photos for comparison:
« Reply #63 on: March 01, 2021, 01:52:44 AM »
I can't tell you how ecstatic I am about your results...
I mean that is ABSOLUTELY PERFECT!
« Reply #64 on: March 01, 2021, 03:10:26 AM »
X2!
« Reply #65 on: March 01, 2021, 03:16:52 AM »
I have to agree...   Fantastic work and material selection, Lloyd!
Edgemontvillage
« Reply #66 on: March 01, 2021, 03:33:23 AM »
Thank you very much gents. Kudos to James for finding the vendor and material!
« Reply #67 on: March 01, 2021, 01:36:52 PM »
You think this would be suitable on the inner 1/4s (coupes) where there is a thickened square with sound deadened applied?
ALLZS
« Reply #68 on: March 01, 2021, 01:53:11 PM »
who is the vendor that has the correct style to reproduce the trunk sound deadner  also was this used on all custom interior car no matter the build date
« Reply #69 on: March 01, 2021, 02:56:43 PM »
James. please clarify the material and vendor you found for this matting.
« Reply #70 on: March 01, 2021, 03:07:21 PM »
Read this and yes to custom interior no matter build date.
http://www.camaros.org/forum/index.php?topic=19021.msg172077#msg172077
Well done Lloyd and great find James..... What a duo in action......
« Reply #71 on: March 01, 2021, 09:36:08 PM »
Dead Nuts On - this is an highly specialized product and they manufacture it for their own inhouse products - underlayment in 65-70 Mustangs. they have a number of detailing products which are very reasonably priced, this is not what most would consider reasonable, however it is correct, you really cannot tell it from original,
I am considering doing them all and doing real jute on the floor side for the footwells of the floor pans like the originals for my GTO.
https://www.deadnutson.com/1969-full-width-trunk-gas-tank-underlayment/
« Reply #72 on: March 01, 2021, 10:35:11 PM »
I just called and ordered for myself.  I spoke to Jack  (very nice fella) on the phone.   He says tell anyone interested!   They make the material themselves, and he says they can only make it in summer as the best temperature is 85-90F... :)
Thanks Lloyd for the information!
« Reply #73 on: March 12, 2021, 04:16:10 PM »
I received the DNO material last night via UPS (and it is dead nuts On!).. :)
When I ordered it, I was given the option to get a 'cut piece' of 12x36 (the size Lloyd stated in his post), OR they could sent me the full piece as they make it for the same price.   I told him to ship the full piece and I'd cut it.    It came in at 24" x 57"  (enough to do two trunk pieces if the 12" is wide enough).. So my question for Lloyd or whomever has the original in their trunk (mine was missing when I purchased the car)..  IS 12" wide sufficient?   If so I could provide the other half to someone or use it elsewhere in my car)...  but if it really needs to be 12.5 or 13" then I want to cut it as close to the original part dimension as possible.
My thanks in advance for any/all responses!  :)
Edgemontvillage
« Reply #74 on: March 12, 2021, 04:58:16 PM »
Gary, glad to hear you're pleased with the material from DNO. Back at Reply #31, George (No Yenko), posted a good photo with dimensions of the (re-created) sound deadener pad from his car that is consistent with the measurements from my original. As shown, the rough dimensions are 9" x 34.5" which is why I ordered a 12" x 36" piece. The larger piece you received should be enough to make two. The precise location of the jack hook bracket varies somewhat so I suggest you trial fit the material first to locate the bracket prior to the cutting the hole for it. Here is a repost of George's photo:
