Author Topic: Trunk sound deadner  (Read 69625 times)
Re: Trunk sound deadner
« Reply #15 on: November 13, 2012, 03:17:45 PM »
Steve, we (CRG) had a discussion about this a few years ago and I believe the consensus was it was used as a barrier for heat. I could be wrong. John can probably shed more light on this.
jeff68
« Reply #16 on: November 13, 2012, 05:03:46 PM »
Gents, he's referring to the trunk paper that was added by Fisher Body on deluxe interior cars.
This one's a 68, but 69 is basically the same.
Any info on whether a convertible would be different?  My 68 convertible has a piece of 'trunk paper', but it isn't located above the muffler.  It runs front to back on the RH side of the trunk recess.  It appears to be the same shape as the picture Ed posted.  I wonder if this was simply a production mistake.
« Reply #17 on: November 13, 2012, 05:06:30 PM »
Jeff, can you post a picture of yours?
There's not a lot of information on these, so I can't answer your question. There's not even a part number in the P&A for them. The trunk mat, yes, but not the paper. I've got a lot of cars in the 68 DB with deluxe interiors but NO paper, so I'm not sure why some have it but others don't. Of course, after 45 years, most have probably disintegrated by now!!
I've NO convertibles in the 68 DB with these, so a picture of what you have would be most welcome.
jeff68
« Reply #18 on: November 13, 2012, 05:11:50 PM »
Ed-  I was just editing my post as you were typing.  See above.
I have a NOS trunk mat I purchased a long time ago.  If it needs protection from the heat, then I definitely want to put something down there.  The original tar-paper type material came apart when it was removed for refinishing the trunk.
« Reply #19 on: November 13, 2012, 06:20:34 PM »
If the purpose of this was 'heat insulation' from the muffler, what is the possibility that when they changed the exhaust configuration, and added the resonators forward of the muffler, that they also deleted this material?   There would be more heat dissipated forward of that point, and less heat at the muffler with that change....
Gary  / 69Z28-RS
Gary, all deluxe interior cars were provided the sound deadener( I've seen it on a 10C of 69 and is also on my 9c of 69 car).
Interesting point Ed makes that its purpose was to dissipate heat. My feeling is that the trunk floor deadener purpose was to attenuate any noise / resonance due to the rear axle and suspension in the open trunk area. The material they use I wouldn't classify as heat resistant.
Ed where is this referenced "It was designed as a heat barrier to keep the heat from the muffler from melting/deforming the trunk mat".
Steve,  I appreciate your comments, and it is interesting that some later cars had it when mine apparently did not.  My car still has the original trunk paint and trunk mat, but no evidence of anything ever having been glued in that location on the trunk floor. (although there is some deteriorating material falling into the trunk area from the hat rack area above which seems like sound deadening material?)..   I agree with you that a tar-based material would be used for noise purposes, ie. 'panel vibration damping', rather than for heat insulation.  I doubt it would provide any significant heat insulation..
Gary
67 RS Ragtop
« Reply #20 on: November 13, 2012, 06:45:47 PM »
  My early build '67 convertible with DeLuxe trim also has the "insulator" as shown in previous pictures (not like the last post of a '68).
« Reply #21 on: November 13, 2012, 06:58:25 PM »
Gary
I agree - that heavy mastic pad material is similar to the mastic pads on the floor in the passenger compartment, and they were used for panel damping to eliminate "drumming" of the floor pan. Photo below shows the floor pan mastic pads used in '68; '69 was similar.
« Reply #22 on: November 18, 2012, 05:04:44 AM »
Can we confirm if the mastic pads were the same all 3 years and between dlx and std interiors? I think they basically are the same as the pic John posted, but the fronts in 68 and 69 don't have that notch removed. Any other differences?
I have a pic of FlowJoe's Firebird floor and it has mastic all down the tunnel and nothing under the front seats, btw.
NoYenko
« Reply #23 on: November 19, 2012, 01:54:08 AM »
Jeff68, That is an interesting picture of your trunk. Shows that your car should have had the tar paper but line worker didn't know where to put it.
Kurt, I don't have as nice a picture as John's but I have three pictures that show the Tar paper installed in my early 69 11A with Deluxe interior. The two bare areas seen, I removed the Tar paper before taking the photo. Hope that helps. George
NoYenko
« Reply #24 on: November 19, 2012, 01:55:20 AM »
One more picture.
CVKUEBER
« Reply #25 on: November 29, 2012, 05:39:28 PM »
Judging from the hole in the deadener for the spare wheel and tire holdown hook, Possibly there to keep the spare from creating rubbing noises or squeaks against the floor ?
Petes L48
« Reply #26 on: November 29, 2012, 10:44:38 PM »
That's what I was thinking, and since the coupe had the spare mounted differently I wonder if this was a spare tire sound deadener item rather than a heat shield.  Is there any discernable pattern between LOS and NOR cars?
Edgemontvillage
« Reply #27 on: December 10, 2018, 05:43:04 AM »
I'm reviving this thread because I'm now researching the trunk insulation pad that was originally on my 4C Norwood built 1969 RS/Z with 712 Deluxe Black (Comfortweave) interior and I'm coming up short where to source suitable replacement material - anyone solve this?
x66 714
« Reply #28 on: December 10, 2018, 10:59:14 AM »
I just thought of this also as mine was destroyed during the trunk floor replacement...Joe
« Reply #29 on: December 10, 2018, 11:03:01 AM »
When you find out what could be used as a suitable source,  Lloyd, I would like to know , as well.
