Author Topic: Speedo Cable Location  (Read 21364 times)
« on: November 11, 2012, 03:29:02 PM »
I was going to ask this in Chick's thread but I didnt want to change the subject.  Does anyone know of any LOS cars that came with a Muncie but did not have the "Muncie hole" in the  firewall?
tmodel66
Re: Speedo Cable Location
« Reply #1 on: November 11, 2012, 04:02:45 PM »
Don't think it would be possible. That was a prerequisite to have the Muncie. It had to be punched when the firewall was pressed.
« Reply #2 on: November 11, 2012, 04:43:51 PM »
I have learned to never say never.  My 68 Z does not have the hole drilled in the firewall.  I am just curious if this is just a goof on the assy line or if there were more early 68 or 67s that this has been seen on in the past.  I am actually on my iPhone or I would post a pic.
« Reply #3 on: November 12, 2012, 01:05:23 AM »
Here is the pic.
IZRSSS
  • Guest
« Reply #4 on: November 12, 2012, 01:35:44 AM »
If LOS cars were excluded it would be mentioned here under transmissions (a couple of paragraphs down);
http://www.camaros.org/options.shtml
tmodel66
« Reply #5 on: November 12, 2012, 01:46:32 AM »
Do you have any paper work with your car? The reason I ask is are you sure it was a 4 speed from the factory?
« Reply #6 on: November 12, 2012, 02:06:40 AM »
The engine is long gone but I have known about this car since I was old enough to understand cars and my father knew of it since '75.  This car has been apart and stationary since '81-'82.  I have no doubts the car is in fact a real deal Z.
« Reply #7 on: November 12, 2012, 02:11:11 AM »
tmodel66
« Reply #8 on: November 12, 2012, 02:38:47 AM »
Is the transmission original to the car? If so which side of the transmission does the cable fasten to? Is there a hole in the tunnel for the cable clip to fasten the cable with? I don't know about this. I've never saw one like yours.
« Reply #9 on: November 12, 2012, 02:47:35 AM »
No Daniel, Darrell's car has no holes or clips in the tunnel area for the speedo.
« Reply #10 on: November 12, 2012, 03:13:39 AM »
That is correct.  Thanks Chick.  Yes this car is overall strange.  Cowl plenum air cleaner, deluxe interior but no tach & gauges or a console and manual steer..
« Reply #11 on: November 12, 2012, 06:41:24 AM »
What's the trans codes and the axle code?
« Reply #12 on: November 12, 2012, 04:54:50 PM »
Is there a plug where the NON-MUNCIE hole is?
Also, can you post a picture of the tire pressure decal on the inside of the glove box?
« Last Edit: November 12, 2012, 06:39:25 PM by Ed Bertrand »
x77-69z28
« Reply #13 on: November 12, 2012, 05:21:33 PM »
i see the plu for the back up light switch. never seen a four speed car without the right cable hole. never say never though!
« Reply #14 on: November 12, 2012, 08:07:19 PM »
If the car was built with a Muncie, it had to have the Muncie hole drilled by the wiper motor; there was no speedo cable in the plant long enough to route from the standard non-Muncie speedo cable hole (which was in all firewalls and got a plastic plug on a Muncie car) over to the passenger side Muncie speedo cable connection.
