Author Topic: Floor Boards  (Read 8174 times)
mrdetails
Floor Boards
« on: July 27, 2006, 02:51:22 PM »
Hello: Are the floor boards the same for a column shift car (auto) and a floor shift car?
Thanks;
Sam
Re: Floor Boards
« Reply #1 on: July 28, 2006, 02:23:26 PM »
Yes.
mrdetails
Re: Floor Boards
« Reply #2 on: July 28, 2006, 04:21:50 PM »
Were the console weld nuts installed in column shift car floors?
Thks.:
Sam
Re: Floor Boards
« Reply #3 on: July 29, 2006, 02:58:42 PM »
There weren't any weld-nuts in the tunnel for the console attachment; the front bracket has two threaded studs on it that go through holes drilled in the floor with loose nuts on the bottom, and the center and rear attachments use Riv-nuts clinched into holes drilled in the floor. Non-console cars had no holes in the floor - the four console attaching holes were drilled at assembly for D55.
