Author Topic: can I use my stock body mounting bolts with poly bushings  (Read 3759 times)
z28rich
« on: October 22, 2012, 05:01:44 PM »
car is a 69
Re: can I use my stock body mounting bolts with poly bushings
« Reply #1 on: October 22, 2012, 05:46:05 PM »
Are the poly bushings thinner or thicker?   Are your original bolts/washers in good shape?
77thor
« Reply #2 on: October 22, 2012, 08:07:10 PM »
I've never seen original bolts that were in good enough shape to reuse.
hotrod68
  • almost finished
« Reply #3 on: October 28, 2012, 03:10:20 AM »
I used my original bolts and washers with urethane bushings and have had no problems whatsoever. Mine is a Southern car and they were in excellent shape. But--new bolts are not that expensive if you choose to go that route. Good luck.
