Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
69 Blue Dot Radio - Stereo Adapter?
« previous
next »
Print
Pages: [
1
Author
Topic: 69 Blue Dot Radio - Stereo Adapter? (Read 8889 times)
KENSTOY1969
Member
on:
July 26, 2006, 01:16:04 AM »
My 69 blue dot stereo radio is only working on the left side. In reviewing an old wiring diagram for the radio there is a green and green/black wires coming out of the connector where the main power plugs into on the radio. Per the diagram these wires are supposed to go to a "stero adapter".
Does anyone have a diagram or can explain where these two wires connect?
Tweet
Logged
Mark
CRG Member
Re: 69 Blue Dot Radio - Stereo Adapter?
Reply #1 on:
July 27, 2006, 10:28:46 AM »
Thats the power feed to the multiplex unit mounted up under the dash behind the glove box.
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
KENSTOY1969
Member
Reply #2 on:
July 28, 2006, 10:28:56 PM »
Mark - found above the glove box. Thanks. Going to replace the Delco DS-501 amplifier and see if that brings the channel alive.
By the way, with a steror radio is there a connection up to the speaker installed in the upper middle of the dash?
Logged
Mark
CRG Member
Reply #3 on:
August 01, 2006, 10:06:54 AM »
Dash speaker is not used (and not even installed) with a Multiplex radio. The multiplex radios used 2 kick panel and two rear deck speakers only.
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Print
Pages: [
1
« previous
next »
Maintenance
