Author Topic: where can I find 69 Camaro shackle bolts?????????  (Read 18033 times)
z28rich
« on: October 04, 2012, 11:31:30 PM »
I want to use my orginal shackles but I lost the bolts :'(  where can I find the correct lenght bolts? GM #3830844
Re: where can I find 69 Camaro shackle bolts?????????
« Reply #1 on: October 04, 2012, 11:54:42 PM »
Heartbeat City doesn't sell the bolts separately, so you'll have to buy the whole shackle kit...
http://www.heartbeatcitycamaro.com/store/product/20217/Rear-shackle-kit-each-correct/
tmodel66
« Reply #2 on: October 04, 2012, 11:55:29 PM »
These folks have just about ANY bolt you will ever need to fit your car. Some will not be spot on in appearance but they will be a direct/correct replacement. I bought the whole kits and replaced all the bolts in my car when we did my restoration.
http://amkproducts.com/
« Reply #3 on: October 05, 2012, 12:44:56 AM »
Call STEVE and tell him Ed from the CRG sent you.
« Reply #4 on: October 05, 2012, 01:55:49 AM »
Daniel is correct and this is the difference in bolt heads. The bolt on the left is one of my restored originals.
« Reply #5 on: October 05, 2012, 02:08:45 AM »
Chick,
 Is that black phosphate on the original bolt?
MyRed67
  • SZZLN 67
« Reply #6 on: October 05, 2012, 02:36:39 AM »
I used AMK a lot for correct fasteners on my restoration, and they are great, when you have a part # to refer to.   The only problem with AMK is they have a $30 minimum policy.  I used to make up a list, when I got around $30 I would place an order.  I have their catalog, and I did not see these bolts as a separate item.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
BillOhio
    • photobucket
« Reply #7 on: October 05, 2012, 03:22:09 AM »
I got a set from Steve along with shackles and they were so clean i could have put right on the car. Good guy
1968 RS 327 4 speed
z28rich
« Reply #8 on: October 05, 2012, 03:36:06 AM »
I hope Steve something. I ordered bolts from Camaro Central and NPD and both were the the wrong length. but they said they were correct.  >:(
MyRed67
  • SZZLN 67
« Reply #9 on: October 05, 2012, 05:50:54 AM »
  It's best to get GOOD used originals, or NOS.  Because the reproduction market really is a crap shoot.
1967 Camaro  LOS  11A
« Reply #10 on: October 05, 2012, 09:11:45 AM »
Chick,
No Mike it is gray phosphate. Looks darker in the picture then how it looks in real life or against the black shackles. I used that and also med. gray phosphate with hardware.
« Reply #11 on: October 05, 2012, 12:25:55 PM »
 Hi Chick,
  As for the Marsden lock nuts, what did you use for that? All those I have ever seen for replacements were zinc plated instead of phosphate. Unless in '69 they were no longer zinc?
Thanks again,
« Reply #12 on: October 06, 2012, 10:10:24 PM »
Mike, hope I was correct but used the marsden nuts that came with the repro kit. Have done that on several hardware pcs. where the orig. bolts were restored but used the repro kits washers/nuts for a nice clean new look. Many times the nuts are pitted and just too rough for restoration IMO. If I'm wrong its an easy swap out :)
CVKUEBER
« Reply #13 on: November 28, 2012, 08:33:53 PM »
GM shackle repair kit #10003072 is the part number. Consists of bolts 5-5/16, plates, and bushings.
« Reply #14 on: November 28, 2012, 08:59:35 PM »
Unfortunately, 10003072 is a service repair kit and doesn't contain any of the correct "original" style items. The kit uses the 70 and up 5-5/16" long bolts. (The 1967-1969 Camaro used a 4-5/8" long bolt.) It also has lock nuts instead of the correct Marsden nuts and the shackles are the later version as well.
Here's a picture:
